Originally Posted by david lamontagn
Just to know if all guys here make a flat spot with Dremel on motor shaft.
Is someoune here have ever had great result without a flatspot??
Maybe it's a stupid question, but i've order my Neu motor from RCM and i'am a litle scared about the fact of flat spot the shaft on a $300 motor
Thank you
Q is why you wouldn't want to make a flatspot? It doesn't have to be big, but if you don't have one its just relying on the setscrew being really tight into the motor shaft and never loosening a bit. With such a big motor, that's alot of power to trust to the little contact the set screw gets w/ the shaft.
Most motors have it already for good reason, but its not hard to do yourself, you really can't damage the motor unless you are doing somethign really really crazy
