LSP convertion....
crazynic
LSP convertion.... - 11.18.2007, 03:00 AM
Hey dudes my names Nick I'm new to RC monster....
I normally hang out at E-savage.com as i run a nice e-sav powered by a novak 4.5 and 14 cells...
I'm getting parts together to perform a BL conversion on a HB lightning pro-R...
So far i have a fiegao 9xl, quark 125b, UBEC, and RC monster heat sinks for both motor and ESC...
The truck will be arriving soon and i also have an RC monster motor mount on its way....
With the RC monster motor mount placing the motor where it does i do not think i will have room to squeeze 14 cells in the chassis...
So i may have to go to LIPO...I have scoured the forum and found that there are many different configurations that people use...
I'm just after some input on what type of LIPO would suit my application best..
I was thinking of going for 4s maybe 5s...i have heard that 6s is way scetchy with the 125b so i wont go there....i will try a 12t pinion first as my backyard "motocross" style track is very tight but big enough for 1:8
Thanks dudes...
squeeforever
squeeforever's Avatar
11.18.2007, 03:22 AM
First off, welcome to RC-M!
I think for you setup, 5S would be perfect. My choice would be a TrueRC pack. I would go with a 5S2P 8000mah pack.
Matthew_Armeni
Matthew_Armeni's Avatar
11.18.2007, 03:35 AM
Welcome to the forums! You sound like you got it all together. You should definitely try to squeeze your cells in there first, no reason to drop more money just yet. But if you do decide to go lipo I suggest you take a look at TrueRC's (great bang for the buck) 8000 packs for runtime and their 6400 packs for a lighter setup. They're about half the price of other lipo's and so far I have yet to hear anything bad about them, so long as you don't draw too many amps(their C rating is lower than other companies). With them being so affordable you could buy 1 4S pack and 1 5S pack and give them both a try.
Also, you should look at BrianG's calculator if you haven't already, here's a link, it's really handy to have. I think a 12T pinion might be a little small for a 9XL, even with a MX style track. You might want to invest in a 13, 14, or 15T so you have some options.
Good luck and keep us updated!
  Send a message via AIM to Matthew_Armeni
crazynic
11.18.2007, 04:56 AM
Thanks guys....
I'm not going to buy any new batteries until i get the truck all put together and see how much room i have to work with....
I did check out that speed calculator and it a very cool tool......
It says my motor speed will be 36318.8 RPM....and top speed will be 34.98 MPH (56.19km/h).....i think i used it right?
I just automatically gear low for my track as it has a history of letting the smoke out of ESC's and several motors!
Thanks heaps for the warm welcome and use full input!
Serum
Serum's Avatar
11.18.2007, 05:08 AM
Here, perhaps this is helpfull to you;
It might give you an idea where to put the cells and the motor.
http://picasaweb.google.com/buikpijn...ningconversion
crazynic
11.18.2007, 05:24 AM
I checked that out in another thread....is that yours she's a beauty!
I was hoping to just use the RC M motor mount but it is not going to let mount the cells like that...that is awesome!
I'm really looking forward to the build some of these trucks look great!
crazynic
11.19.2007, 05:37 AM
While waiting for my chassis to arrive...I have been looking at the prices and specs of lipo chargers out of interest....
If you have to charge a lipo at 1c or just below.....does that mean to charge a 5000mah lipo you must have a charger that is capable of 5 amps?
Or can you succesfully charge at like .5c or somthing?
I ask all this as there are some nice chargers that have a max rate of 4 and 5amp....would that be any good for charging higher capacity lipo's like 6000mah or 8000mah for example??
What are some popular chargers that wont deprive me of to much beer money
bdebde
That's All Folks!
bdebde's Avatar
11.19.2007, 04:28 PM
You can charge at less than 1c, but it will just take longer.
squeeforever
11.19.2007, 04:53 PM
For a charger, I would look into the Hyperions or the E-Stations.
jnev
jnev's Avatar
11.19.2007, 05:06 PM
This may be a good charger for you:
http://www.maxamps.com/EOS0610i.htm
It has a built in balancer and is capable of 10 amps.
A4DTM
11.19.2007, 08:27 PM
im not sure how your cells are layed out.. 7 sxs? or a 6cell stick with one on top?
my trucks got two 5s1p 5000mah True-RC packs wired in parallel.
http://www.rc-monster.com/forum/showthread.php?t=6529
the packs are 34mm x 50mm x 160mm, and just barely fit. if your packs are smaller than that, you shouldn't have any problem w/ a similar layout.
crazynic
11.21.2007, 09:46 PM
Cool thanks guys...
So it sounds like you need a charger around the 8-10 amp region to be able to charge high capacity lipo's in a decent time....
A4DTM.....my current packs are 7 cell side x side packs and require quite a bit of real estate to mount...
I'm seriously considering lipo's for this conversion mainly to save room on the chassis and to keep the weight down...
crazynic
11.26.2007, 04:10 AM
Well the chassis arrived today
It looks nicer than i expected
So all I'm waiting for now is the motor mount and pinion.....then i can start building this baby...
I'll post some pic's as soon as i start the build....but right now its just a rolling chassis as it came out of the box....and im sure every one has seen one of those before
PS: Is Mike on holidays or something?......he has not responded to my mails....
Oh well patience is a virtue!....
squeeforever
11.26.2007, 09:26 AM
Where did you send the e-mails?
crazynic
11.26.2007, 04:44 PM
I sent the mail to the right place......He replied today he must be busy as hell trying to keep up with the demands of all us RC junkies
