Converting LSP into Lighting GTX
Blunten
Converting LSP into Lighting GTX - 12.31.2007, 12:25 AM
Anyone knows if the chassis on the Lighting GTX is a direct bolt on to an LSP? Both of these trucks shares alot of the same parts. On the drivetrain, the only difference is the center front driver shaft which is 141mm on the GTX compared to 94mm on the LSP. This is almost 2 inch difference. Has anyone tried this?
Blunten
bdebde
That's All Folks!
bdebde's Avatar
12.31.2007, 01:11 AM
If the front drive shaft is longer, then the chassis is probably longer.
