UBEC/tapping from 4s w/balance tabs?
JeffEmbracedDC
JeffEmbracedDC's Avatar
UBEC/tapping from 4s w/balance tabs? - 12.31.2007, 02:11 AM
So, I could always use a UBEC...
Though, let's say I wanted a 7.4v output (at about 3amps) could I just tap directly off of the balancing tab? I understand that servos may not be rated for 7.4v, but that's beside the discussion. The question is just - can I pull 2S (7.4v) voltage (at 2-3amps) from the balancing tabs?
Thanks.
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
aqwut
Brushless Heavy Weight....
aqwut's Avatar
12.31.2007, 02:30 AM
you could... but it's not too good for the lipos... it will make the cells off balance... .. but it wouldn't be 7.4Vs.. it would be over 8.0 Volts...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
JeffEmbracedDC
12.31.2007, 02:35 AM
Ohh duh. Okay yeah I should have thought of that. :)
So my nest question is.. Are there any voltage regulators/UBECs that output 7-8v instead of 5/6?
Thanks.
12.31.2007, 02:38 AM
The castle creations bec can go up to 9.6v.
Serum
Serum's Avatar
01.01.2008, 02:04 PM
I would't use the balancing tabs for this purpose, rather take a castle ubec..
david lamontagn
01.01.2008, 02:35 PM
++++++++++1, that,s what i use and it's small, powerfull and very userfriendly
