2600 Kv rated motors? which one?
Revracer
Revracer's Avatar
2600 Kv rated motors? which one? - 01.06.2008, 09:13 PM
okay so i was looking at the Ammo 36-56-2600 for my race spec revo. tekno used a neu 1512/2d motor(2600Kv) and the mamba max controler, which is the same kv rating and esc that i was going to use. i was wondering if there was a nemesis or feigao XL motor with a 2600Kv rating(or similar 2500-2700). it will be run on 3s lipo and set up to race. cant afford the neu, or any motor that cost more than $120 so if someone could point to a feigao or similar motor that be great. thanks
jhautz
jhautz's Avatar
01.06.2008, 09:55 PM
http://cgi.ebay.com/Feigao-540-10L-B...QQcmdZViewItem
Here a Feigao 10L on ebay. 2458KV
You could also use a Feigao 7xl at 2382kv and gear it a tooth or 2 higher. The larger motor should allow the taller gearing no problem. Thats probably your best bet IMO.
http://www.rc-monster.com/proddetail...WAND_XL&cat=20
to make it...
or break it...
Silent...But Deadly
Revracer
Revracer's Avatar
01.06.2008, 10:04 PM
thats showin the 7XL is only 2145Kv. thats too low to run on 3s lipo isnt it?
jnev
jnev's Avatar
01.06.2008, 10:18 PM
Those specs have been wrong for a while now. The actual KV is what jhautz said: 2382
squeeforever
squeeforever's Avatar
01.06.2008, 11:20 PM
Its not wrong...Its the loaded KV vs. the unloaded KV...
jhautz
jhautz's Avatar
01.06.2008, 11:26 PM
unloaded is what almost every manufacturer goes by except Lehner/BK so its the one that gives you the best comarison from brand to brand.
to make it...
or break it...
Silent...But Deadly
Revracer
Revracer's Avatar
01.06.2008, 10:20 PM
ok thats cool then. and i could gear that probly 18/36 instead of the 18/38 i planned and get about 35mph speeds like i would with the 2600 ammo? is there another motor out other than the neu that would get about 2600 Kv?
01.06.2008, 10:36 PM
if you can spare the dough ($210) check the 6xl motor out on this page.
http://finedesignrc.com/motorshacker.asp
if you can bore out your 5mm pinion to 6mm check this motor out.
https://www.unitedhobbies.com/UNITED...idProduct=4938
much more power than the feigao.
jhautz
jhautz's Avatar
01.06.2008, 10:57 PM
finedesingrc has a Nemisis 6xl also. Its a feaigo with a blue can.
to make it...
or break it...
Silent...But Deadly
Revracer
Revracer's Avatar
01.06.2008, 11:29 PM
okay well like i said before i cant put much mroe than $150 into the motor. so a feigao 7xl or 6xl both on 18/36 gearing will give me about 35mph speeds and wheelies all over the place? thats what im looking for. enough torque to rip the wheels up, and fast enough to be a track truck on 3s lipo. and no i cant bore out the tekno electriclutch thingy. i dont want to try atleast. any other inexpensive but crazy powered motors out there?
squeeforever
01.06.2008, 11:33 PM
I would chose the Lehner XXL. There around $175 I think.
jhautz
jhautz's Avatar
01.06.2008, 11:35 PM
good luck finding one though.
to make it...
or break it...
Silent...But Deadly
Revracer
Revracer's Avatar
but will that fit on the tekno kit? i think the tekno kit cant take anythign more than like 78mm long or something...
Revracer
Revracer's Avatar
01.07.2008, 12:08 AM
will the feigao 6xl pull the wheels up easily on 3s with a 18/36 gearing?
jhautz
jhautz's Avatar
01.07.2008, 12:11 AM
I doubt anything will on 3s
If you want power go with 4s or more
to make it...
or break it...
Silent...But Deadly
