Truerc 12000mah 2s pack ?
speedy
Truerc 12000mah 2s pack ? - 01.13.2008, 10:19 AM
Hi !
Will a truerc 12000mah 2s pack fit into the 3905 e-maxx battery mounts ?
if i remove the stock plastic battery "straps" and run a singel motor setup with the motor mounted in the top motor mount and maby grind the lower edge of the motor mount ?
austinmaxx
01.14.2008, 04:11 PM
Probably I have (2) 8000mah 7.4 2s maxamp lipos and they fit easily and I have to use the little foam spacer they give you for running 6cell packs and there is room for heavy moddding for longer packs if it is needed....I must say it might be alot of weight with that much battery size...do you need that big a batt?
speedy
01.14.2008, 06:42 PM
The two 12000mah 2s packs weights the same as 14 4500mah + nimh cells but will give me like 60min + runtime and i think that woud be great :)
glassdoctor
TEAM FUSION
glassdoctor's Avatar
01.14.2008, 08:19 PM
I have saddle pack made from two 2s 12000mah packs... its huge... but the runtime is awesome of course and you cant hurt the thing, lol
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
BP-Revo
BMW M Power!
BP-Revo's Avatar
01.14.2008, 10:56 PM
Yea...12000mah at 10c is still 120 amps...
Personally I'd go with a pair of 8000 packs to help cut down on weight, or maybe even a bunch of 4000 packs.
I'm very weight conscious of all my trucks, especially my MT's...
