Which lipo to go with?
cemetery gates
Which lipo to go with? - 01.08.2008, 06:24 PM
Hi all, I was just wondering which lipo I should I go with for my crt.5ext. It is running a MM with a mega ACn car motor (4580kv).
I have narrowed my decision down to a few. All 2s.
http://www3.towerhobbies.com/cgi-bin...?&I=LXRWF7&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXSRT6&P=7
I wish I could fit other flightpowers, but that requires drilling new holes for battery mounting. Any others I should consider?
Thanks!
t-maxxracer32
t-maxxracer32's Avatar
01.08.2008, 06:30 PM
they are basically the same exact pack except for a different brand.
do they have the same cells?
i know NOTHING about enerlend cells and all that so idk.
id go with flightpower though. this is what i have and i love it!
01.08.2008, 06:38 PM
Why not a nue hardshell 5000 25c one?
01.08.2008, 06:43 PM
Have a look at this:
I run the 3s2p version in my ext crt.5 and it fits great. Still allows room for the mm behind the battery too. I get great runtimes, at least 30mins, mixed bashing!
cemetery gates
01.08.2008, 07:07 PM
Well, I would like to stick with flightpower/trackpower because I can get them at my lhs; since I work there, I can get a discount.
I really don't like maxamps at all. I'm running a maxamps 2s 4Ah lipo now and it can barely handle 60amps.(voltage drops to 3.1v/cell)
I think I'm gonna drill some holes in the chassis to make room for some of the longer flightpowers.
Bye
01.08.2008, 07:13 PM
Bye
I know what you mean about the 4ah packs, they only work well in a 2p configuration, or 4s and higher setup. I have had alot of success with my 2100 cells, I ran 2 2100 3s packs in parallel in my emaxx with a 380c 7l motor. It was geared for 45 and they could delive under that load. The motor and esc got hot, but the lipos stayed just warm. I am sure the flightpower are better packs though.
rchippie
rchippie's Avatar
02.04.2008, 07:37 PM
James is that with the stock strap or the optinal one ?. Thank's
REAL MEN RUN BRUSHLESS
02.04.2008, 07:52 PM
Hey Mike, I use the stock strap and put some small al spacers under the posts. They look to be about 10mm tall, I also have a piece of velcro under the batt to keep it in place. With the spavers the top hole in the post is in jst the right place to keep it all tied down tight. The battery does get close to the spur, so I just taped a think piece of sheet steel to the pack in case it gets moved towards the spur. Very happy with these cells, I think that they are maxamp's best.
rchippie
rchippie's Avatar
02.04.2008, 08:03 PM
Thank's james mike said the same thing today about these cells.
Patrick
Patrick's Avatar
01.08.2008, 08:54 PM
I would get the trackpower pack. They aren't 20C anymore, the newer ones are the 25C cells like in the flightpower pack.
They are the same price as the flightpower pack even though you get the hard case.
You need to get the right balance harness for the trackpower though (if you already have the regular flightpower balancer). Or get the gold V-Balance.
cadima
01.08.2008, 10:46 PM
flightpower = enerland = Polyquest = PolyRC Extreme Series = Thunderpower Extreme Series. Only difference is they're assembled by different folks. I think some other brands are also the same enerland cells but not sure. The giveaway is in the size of the cells.
It's possible some of em get the cream of the crop and others get the remainders, but fret not and choose any of the above with confidence. If you go the Maxamps route, or any other "light" pack, best of luck to you.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
01.08.2008, 10:51 PM
I'm sure they come from the same factory in S. Korea... I agree....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
t-maxxracer32
01.08.2008, 11:30 PM
definetly would not suprise me.
gixxer
gixxer's Avatar
01.09.2008, 02:23 AM
out of those two I would pick the car pack, because of the hard case.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
cemetery gates
01.09.2008, 01:50 PM
Would the hard case really help that much? I am looking to get 2 packs; they do not have to be the same either. Also would I see a performance difference between these?
http://www3.towerhobbies.com/cgi-bin...?&I=LXRWE2&P=7
The motor I am running says 45amps max.
Also, if I'm at the track and need to fast charge them, say at 2c(with the balancer) would it be ok? I an using the mrc 989 charger and it says 1.25c max charge rate for lipos, can that be overridden?
Thanks!
