thunder power 1010c charging/balancing?
tallyram
tallyram's Avatar
thunder power 1010c charging/balancing? - 02.20.2008, 07:48 PM
i've had this charger for around 6 mos. and i'm not really sure if my charging/balancing method is the best way possible for my equipment. i use the 1010c along with the 205v balancer connected to each other to balance/charge my evo25 5s packs(one at a time). does my equipment reduce the charge rate so that its charge rate is lower than the balancer's bleed/discharge rate? not sure if i should keep charging and balancing together or do one before the other!
luxury!
  Send a message via AIM to tallyram
tallyram
tallyram's Avatar
02.21.2008, 10:10 PM
anyone?
luxury!
Haldir
02.22.2008, 04:07 AM
That sounds fine to me.
