neu motor shaft coming out?
t-maxxracer32
t-maxxracer32's Avatar
neu motor shaft coming out? - 03.15.2008, 04:08 PM
hey im not sure if this is a normal thing but the shaft is starting to come out and so it is making me strip my STEEL spur gear...
i have to take off the mount and hammer it back in. im guessing this is not a smart idea? ive only done it twice so ihope i havent screwed too much up.
let me know if theres anything i can do.
chilledoutuk
03.15.2008, 04:34 PM
erm i would say perhaps contact steve neu and see if he will fix it alternatively take the motor apart and try to bond the magnet to the shaft using green loctite or something like that.
03.15.2008, 04:46 PM
Is it a bearing issue, or is the magnet seperating from the shaft? Either way, I'd contact Neu and not worry about messing it up further...
t-maxxracer32
03.15.2008, 04:53 PM
got a link to their site?
skellyo
skellyo's Avatar
03.15.2008, 05:05 PM
www.neumotors.com
wallot
wallot's Avatar
03.15.2008, 05:07 PM
http://www.neumotors.com/20061222/Welcome.html
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
t-maxxracer32
03.16.2008, 06:14 AM
how lame.
i googled "neu motor" and that didnt pop up lol...
ill have to call when i have time.
thanks alot.
Patrick
Patrick's Avatar
03.16.2008, 06:44 AM
Originally Posted by t-maxxracer32 View Post
how lame.
Add an "s" to the end, and it will be at the top of the list. Annoying, I know.
How far does the shaft come out?
t-maxxracer32
03.16.2008, 12:16 PM
that is weird.
umm... well. i had it set perfectly so the pinion is touching the spur completely. after driving for a couple hours (took about a week) it started slowly moving and one day it moved so far the pinion wasnt even touching the spur.
yesterday i hit it back in and drove it and within 5 minutes it went back...
Finnster
KillaHurtz
Finnster's Avatar
03.16.2008, 04:55 PM
Mine was doing the same thing. It was coming out and tearing up the slipper pads on my Revo. I thought it was the pinion coming loose, as it slipped just a bit.
Was running it yesterday for the 1st time since Nov, ran fine for a bit, then shaft came way out and now the power is weak and its stuttering at low throttle. I think something has happened to the motor...not good as I haven't had it that long..
hopefully you'll have better luck
03.16.2008, 07:18 PM
Oh great, now even the Neus are falling apart...
