Neu Motors and dust
Shark413
Shark413's Avatar
Neu Motors and dust - 03.26.2008, 02:51 AM
I got a question for any Neu owners out there. How many of you are using some kind of dust cover on your motor? Is it really necessary? I assume the holes are for cooling, and the motor has roots in the aircraft world where dust isn't as much of an issue. Does covering the holes cut down on cooling but keep abrasive dirt out of the motor? Is it better to leave the holes open for cooling and just blow the dust out on a regular basis? If left uncovered dirt will probably cause more bearing wear, but would this be partially offset by the additional cooling? Anyone try foam filters to cover the holes? Most brushed motors have open endbells and some even have holes/slots cut in the can for cooling.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
03.26.2008, 03:00 AM
Do you have one of these on?
http://www.rc-monster.com/proddetail...EUcover&cat=20
Shark413
Shark413's Avatar
03.26.2008, 03:38 AM
RC_KAOS, yes I have the RC-Monster dust cap. I was just wondering why Neu would put so many cooling holes in the motor can.
03.26.2008, 04:16 AM
the difference in temp between having the holes covered and uncovered would be minimal. One of the great design features of brushless motors is that the windings are mechanically connected to the aluminum can, which disipates heat quite effectively. If you are running in dust protect your investment, cover those holes.
pipeous
5th Scale Guy
pipeous's Avatar
03.26.2008, 12:33 PM
I made my own foam cover. I cut a thick chunk of foam and hollowed part out, cut slots for the motor wires and zap strap it to the motor can. I used a little oil on the foam too to grab the dirt. I just cleaned the motor last night and seems to work good as there was little crud in the motor.
Shark413
Shark413's Avatar
03.26.2008, 01:29 PM
Hey guys thanks for the replies. I will use the cover to keep the dust/dirt out of the motor.
DRIFT_BUGGY
04.14.2008, 07:31 AM
Got a pic?
03.26.2008, 01:47 PM
And if you want to protect it even more, get the aluminum front plate. Not only does it keep the dust out, but prevents screws from hitting the coils if screwed in too far. Plus, it helps if you happen to strip out the threads or break a screw.
Shark413
Shark413's Avatar
03.26.2008, 01:51 PM
BrianG, I saw that front plate and I thought it would be perfect for my mechanical brake setup. The plate would act as a spacer to move the motor back to clear the brake rotors.
03.26.2008, 01:53 PM
Yup, I guess it does that too. Such a small part, yet so versatile!
Edumakated
03.26.2008, 02:05 PM
I use the rc-monster rear cover. I just put some duct tape or electrical tape over the front holes. The rc-monster aluminum plate doesn't fit the new Neu motors now. I believe the new batch of motors only has a .75 shaft. I originally had a 1515 1y and the aluminum plate worked perfectly. I believe that shaft was 1 inch. However, I switched to the 1512 and the shaft is shorter and it won't work with the aluminum plate because it won't leave enough room for the pinion to grab.
03.26.2008, 02:57 PM
What about if you flip the pinion around??
Edumakated
03.26.2008, 03:06 PM
Nope, still too short with the aluminum plate.
jordan...
one.five.two.seven
03.27.2008, 06:07 AM
So i see you can get Neu motors with fans mounted to them:
http://www.amainhobbies.com/product_...ducts_id/14428
These look awesome and if Neu is installing these, dust can't be a HUGE problem(???)...
The Bigmaxximums also have fans on them, has anyone with a BM ever had troubles with dust getting in the motor?
thanks
jordan
rhylsadar
rhylsadar's Avatar
03.27.2008, 06:35 AM
hi
the question is if those fans on the NEU blow directly into the motor or just blow over the can. the plettenberg fans only create a blow over the finned can. the can itself is closed.
the NEU are still aircraft motors. i don't get it that they have not yet designed new motors with closed cans as obviously they are efficient enough to run cool without all those holes. its the same sad thing with those new kontronik kira motors or the new lenher versions with fans. they are just too open for real offroad applications and blow directly into the motor.
the fins on the pletti are gone but you can imagine where they were....before the little stone got in there. but imagine what would have happened if the fan blew that stone into the motor can itself......
bye
rhylsadar
______________________
Exercitatio artem paravit
rhylsadar at youtube
