Jammin CRT - middle diff
Nova-Neo
Jammin CRT - middle diff - 03.29.2008, 08:57 AM
Hello and sorry for my bad english, but i come from germany
I have one question:
Can i use the Kyosho 46 tooth nylon spur without any modifications on my CRT middle diff ? And when not, what i have to do ?
My Setup now: 12xl / Kontronik 80-6-18 / gearing 16/62 / on 5s lipo or 16 cells NiMh !!!
With the Kyosho 46 i will use 12/46 or 13/46...
Thanks for your help...
Nova-Neo
03.29.2008, 11:33 AM
Yes the kyosho spur will fit the crt diff cup, you may need a paper gasket, as the crt might use an o-ring to seal with the current steel spur ear. Or you can use some sort of silicone or other glue to make a seal.
Just make sure that you lower the pinion tooth count to compensate for the smaller spur, but it looks like you have already figured that out!
Nova-Neo
03.29.2008, 03:59 PM
Okay fine, thanks for your help
I think it works:
Now 62/16 = 3,87 and then 46/12 = 3,83 or 46/13 = 3,53 for a little bit more speed !
Jammin
Jammin's Avatar
03.29.2008, 07:20 PM
I just reused the oring with my kyosho spur and it worked fine. I had to use a 10t on 4s. You might want to get an 11t just incase.
Nova-Neo
03.29.2008, 08:39 PM
The combination 5s and XL/12 works fine.
I have more rpm with this as with the combination 4s and XL/10 ore ist this a error in my reasoning !
I think 5s and Xl/12 is a little bit to much
03.29.2008, 09:59 PM
You have about 1k rpm more with the 12xl on 5s. Still a bit low on the motor speed though, 25k rpm is about 10k rpm less than most run the xl feigaos at.
Nova-Neo
03.29.2008, 10:19 PM
Sorry my mistake, i want to say XL/11 !!!
@lincpimp:
what do you think is the best XL with 5s lipo in jammin ? Lower than XL/12 ?
