schulze 18.97 on 5s, what motor
schulze 18.97 on 5s, what motor - 04.04.2008, 05:27 PM
I've narrowed it down to either a kb45 8l 2200kv or a medusa research 36-60 2000kv. Now, then schulze is made for 4 and 6 pole plettys, and the timing is set up for that. The medusa is a 4 pole, and is rated for 900 watts. The kb is a 2 poler and rated well over 2000 watts. Given the schulzes combustible reputation, am I better running a lower watt load? Should I care about the pole count? Batteries will be 2x zippy 5s 5000mah in parallel for 10,000mah.
lutach
lutach's Avatar
04.04.2008, 07:49 PM
I'll be just checking in here to see how your 18.97 is doing after you start running your vehicle.
04.05.2008, 08:34 AM
the burnt up ones always seem to be because of connectors, so I'm soldering directly. anyone have any input on my motor querys?
lutach
lutach's Avatar
04.05.2008, 08:47 AM
I wouldn't blame the connectors. It looks more like a design problem with the 18.97 and higher AMP models (Except the one that uses the big FETs). I haven't done a search to see if the lower AMP models had done this as well. I think the other guys that had the unpleasent experiance probably had the right wire length and it still went up in flames. I hope you don't get to see it. If my truck was further away from me, it would've burned down for sure.
04.05.2008, 09:05 AM
so....... am I better running a lower wattage motor to keep amps low on this esc?
04.05.2008, 09:43 AM
What is this going in? My experience with the KB45 motors is that they really do not get hot, and have tons of power. You may overload the medusa, depending on gearing and vehicle weight. Plus you will have a decent amount of battery weight. I just ordered the 1500kv 60mm medusa motor, and will use it in a buggy. Hope they come out with a longer can, that will be better for a larger rc with heavier tires, etc.
lutach
lutach's Avatar
04.05.2008, 10:20 AM
My 18.97flamed out with max of 75A spikes.
