looking to purchase lipo today!
plettenbergs
plettenbergs's Avatar
looking to purchase lipo today! - 04.13.2008, 09:50 AM
will 1 bigmaximum with schulze 18.97 esc work with 2 5s 5000mah LIPO batts?....i have the dual setup now but do not seem to be able to harness the HORSES!....if i have to drop a motor i do not want 2-$250 batts laying around that i cant use!.....I AM LOOKOING FOR ADVISE!.....I STILL CANT DECIDE WHICH BATTS TO GET?
jordan...
one.five.two.seven
04.13.2008, 10:02 AM
you could 2 packs in parallel, then you would have the equivalent of a 10,000mah 5s pack. However, I don't think the 18.97 will hold up to 10s without spectacularly exploding...
brushlessboy16
brushlessboy16's Avatar
04.13.2008, 10:15 AM
I would give these a shot,i have their 4000mah set in my raze, they are great packs and an even better price
http://www.hobbycity.com/hobbycity/s...idProduct=6352
great price!...$107
plettenbergs
great price!...$107 - 04.13.2008, 10:26 AM
will this plug work with hyperion charger/discharger?
Capacity: 5000mAh
Voltage: 5S/18.5v/5 cell
Discharge: 20C ~ 30C
Weight: 659g
Size: 160 x 51 x 40mm
Connectors: JST-XH for balance/charge and Deans style T-connector for discharge
what do you guys think?
keeping duals for now!
plettenbergs
keeping duals for now! - 04.13.2008, 10:30 AM
i love the power!
forementioned batts on back order?
plettenbergs
forementioned batts on back order? - 04.13.2008, 10:38 AM
dang...price seems toooo low !
83gt
04.13.2008, 10:21 AM
So are you going to remove one of the pletts and run a single setup ? Or were you thinking of keeping the dual ESC's and using a 5s on each one ?
Need to know how you intend to hook these up before making recommendations.
J.
Sammus
Sammus's Avatar
JST-XH is the most standard plug in that all the chinese brands use it. That said, all the "big" brands have their own plug style which is pretty annoying. In short, to use that plug you would need the hyperion -> XH balance plug converter, which seems to be sold out in every store I've managed to find that stocks hyperion gear. Either that or just get some 7 pin hyp plugs and rewire your batts.
that being said?
plettenbergs
that being said? - 04.13.2008, 01:21 PM
i should probably get batts from thew place where i get the charger!..batts with HYperion charge jacks?...RIGHT?
check out my order?
plettenbergs
check out my order? - 04.13.2008, 01:39 PM
2)PQ-5350LP-4S 180.50 $361.00
1)HP-EOS0610i DUO $269.95
Subtotal $630.95
should i press pay?
brushlessboy16
04.13.2008, 01:40 PM
nooo, get the Zippy packs, they are AMAZING
cant
plettenbergs
cant - 04.13.2008, 01:41 PM
they are out of stock?
brushlessboy16
04.13.2008, 01:46 PM
yes, but u can get 2 or 3 of them for the same price
i will wait!
plettenbergs
i will wait! - 04.13.2008, 01:57 PM
i will give them a couple days to see if stock comes up!....i love the price!....i might work my way up to 5s....i am already having drive line issues!...WHAT DO YOU THINK?...i do not want to cook the esc,s
04.13.2008, 02:16 PM
its about time you go lipo! and you can't remove a pletty until we have video of the dual setup! Did you shear the roll pin of the input shaft? replace that weak pin with an allen wrench or drill bit, the tool grade steel lasts much better
