how to solder 6.5 bullets
blueb8llz
how to solder 6.5 bullets - 05.12.2008, 07:25 PM
im trying to solder my 10g wires with the 6.5 bullets. do i fill up the female bullets with solder up to the little holes and then stick the wire into the female?
or does anyone have good ways to do this
brushlessboy16
brushlessboy16's Avatar
05.12.2008, 07:29 PM
I just rest the wire in the connector then fill it to the side hole
05.12.2008, 07:33 PM
You will want to tin the wire, and the inside of the cup. Then I push the wire into the cup, while keeping the heat on the cup. Make sure all of the solder has heated thru and you should be good.
Cartwheels
05.12.2008, 07:50 PM
I find that using one of those mini torches for heating up the bigger connectors works really well. Once it's hot and tinned you just shove the tinned wire in. Usually the connector stays hot for a little longer this way which makes it easy to get the wire in there.
blueb8llz
05.12.2008, 08:14 PM
ouu ok got it thanks for the tips
aqwut
Brushless Heavy Weight....
aqwut's Avatar
05.13.2008, 01:11 AM
I use the same method as Linc..... I love the torch for desoldering...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
tha5150
tha5150's Avatar
05.16.2008, 06:39 PM
i just got my bullets in and i cant seem to heat them up enough to melt the solder in the cup. 100/140w gun too...
Duster_360
05.16.2008, 09:04 PM
I use a 100/140 gun also except for big stuff. I had to make adapters from 5.5bullets to deans and had no prob using the gun.
When you're heating the bullet to tin it, touch the solder to the gun tip - this bit of molten solder on the tip increases the heat transfer to the bullet. The solder I'm holding in the bullet will melt almost as soon as I do this.
Be ready to solder the wire into the bullet, I never turn the gun off and go straight to the wire. I have the holes oriented so I can see when everything liquifies. Then I turn it off and hold until things cool.
brushlessboy16
05.16.2008, 06:52 PM
hmm, put the gun's tip into the side hole and keep contact, feed solder right next to the tip where it melts, the solder should transfer heat better and eventually from the connector to the wire
aqwut
aqwut's Avatar
05.16.2008, 10:53 PM
try using the wood burning tips.. that's awesome for soldering big stuff... I always have a nice denim material rag & a wet natural sponge for cleaning...
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.17.2008, 12:13 AM
Make sure your tip is nice and tinned, to get good heat transfer; makes a big difference.
tha5150
tha5150's Avatar
05.17.2008, 05:43 PM
i am using a 140/100w gun and that should be more than enough to do this.
funny thing. i got a new tip and vwalla. worked like a charm.
Duster_360
05.17.2008, 08:17 PM
Mine is an older Weller. Every so often, I check to make sure the nuts that hold the tip are tight. If they get the least little bit loose, performance goes down. When I notice its not heating like normal, thats the first thing I check and make sur ethey are tight.
My Weller gun is better than 25yrs old and I'm using the 2nd tip. They last a long time if cared for.
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
05.17.2008, 08:22 PM
I use a 80w weller iron, the SP80L. It has a HUGE massive tip on it which has lots of thermal mass, great for showing those 6.5mm bullets who's boss. The guns will work, but since the tip has not much thermal mass, they are a bit slower, even though the watts are higher. My iron melts solder in the cup in about 2 seconds or less.
Using a bit of solder on the iron to form a "heat bridge" is essential. With a dry tip, it'll take forever to get the cup hot. Wetting the tip a bit with solder makes a huge difference.
Be careful after you've soldered it too, guys. Those bullets retain a lot of heat and can burn the bajeezus out of ya for a long time.
brushlessboy16
05.17.2008, 09:07 PM
dont forget the wire, it gets pretty hot too.... thats how i lost a few fingerprints :D
