Pinion stuck on 9XL?
Fkyx
Pinion stuck on 9XL? - 05.27.2008, 06:05 PM
I'm having trouble removing the pinion from my 9XL. I believe it's one of the pinions Mike sells. Unfortunately, because it won't come off, I can't remove the motor from the motor mount on the E-Maxx 3905 tranny. Do you guys have any ideas on how to remove it without bending the motor shaft?
dirt101
dirt101's Avatar
05.27.2008, 06:09 PM
for some reason I just dont see the shaft bending. im guessing you meant the mount.
my best guess is to maybe heat it up a little bit or throw some pb blaster on it.
Fkyx
05.27.2008, 06:11 PM
I did mean the shaft... but I guess it wouldn't be good to bend the mount either. lol
I'll try hitting it with my butane soldering iron's blow torch attachment for a while when I get a chance. Thanks.
05.27.2008, 06:58 PM
I had (have) the same problem with my 9L motor. Still can't get the damn thing off!
blueb8llz
05.27.2008, 07:06 PM
theres a device called a pinion puller. but i had the same problem and i just put a screwdriver (the shaft) on the left and right side of the pinion (underneath it of course) and i just yanked on the screwdriver and it came off.
05.27.2008, 07:09 PM
Yeah, I need one of those. Where do I get one?
azjc
05.27.2008, 07:11 PM
I had the same problem on a 9L on my Rustler I pretty much did what BB8 suggested I never had to use heat, if you use heat apply only on the pinion and it should loosen up
lxmuff
lxmuff's Avatar
05.27.2008, 07:28 PM
If you can get the set screw from the pinion, run it without the set screw and the torque should get it loose.
Fkyx
05.28.2008, 01:54 AM
Actually, I've been running it for a week or two without the set screw in. It's pretty well stuck on there. I'll try prying like a couple guys have suggested.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
05.27.2008, 07:39 PM
Depending on why they are stuck just use a bit of heat from a heat gun. Mine are normally stuck due to loctite and you just have to heat the pinion a little bit and she will pop right off. The motor will only get a little warm if you direct the heat at the pinion.
tc3_racer_001
tc3_racer_001's Avatar
05.28.2008, 01:35 AM
happened to me, as i forced it on there and didnt ever use a pinion set screw, but when i tried to get it off i couldnt... got it off eventually by gripping another bit of the shaft with pliers and levering off with a screwdriver as mentioned above.... took me about 10 minutes to get it off but once i figured it out its easy :)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
blueb8llz
05.28.2008, 03:40 AM
try my method that i posted up above...you just grip the motor with your left hand, and grip the shafts of the screwdrivers with your right hand using your index and middle finger. sorta making a claw with them two fingers but upside down and just yank it upwards. try heating the sucker up with the strongest soldering iron you got first too.
bruce750i
bruce750i's Avatar
05.28.2008, 10:34 AM
A big screwdriver and pry it off with some leverage, always pry close to the shaft. Sometimes I use the little flat open end traxxas wrenches to wedge in around the motor shaft and pry to get the pinion moving.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
05.28.2008, 11:02 AM
If it is running without the set screws, it is on there pretty good. I think heat and a gear puller is the best answer - any hardware store will likely have a small gear puller that would work. Next time, you may go a little lighter on the threadlock (only a little dab on the set screw is needed - blue loctitie). :)
azjc
05.28.2008, 06:49 PM
I have had a pinion stuck on a shaft without using any threadlock
