Can't set-up my MMM (please help...) -
06.20.2008, 12:08 PM
Hello,
I've finally gotten everything I need to run my E-Revo (conversion). Batteries are fully charged, transmitter (Futaba 3PM) has been tested on another truck. (And the transmitter has had its throttle servo reversed, as mentioned in the MMM manual.)
I power-up the MMM with the throttle held down. I hear the proper tone, then the green light blinks. I push the throttle again and the MMM does 4 tones.
And here's the trouble: instead of having a red led blinking, I have the green and yellow leds on, the red blinking, and the MMM beeping repeatedly. I try putting the transmitter in reverse, but nothing happens.
Nowhere in the manual or the website have I found a reference to that LED-state.
Can anyone help me?
Loa
P.S. If someone from castle reads this: why isn't there a LED-state explanation in the manual? The MMM is telling me something but I can't decode what it is...
06.20.2008, 12:24 PM
Reverse your throttle channel, futaba radios have to have the throttle channel reversed to work with most escs.
06.20.2008, 12:48 PM
Thanks for the tip! :-)
The MMM falls into that multi-LED and beeping sound immediately after it accepts my forward throttle. I'm not even touching reverse...
Any ideas?
Loa
06.20.2008, 12:54 PM
Make sure that you have all of the trims centered and no exponetial or any other settings off zero. I have a 3pm and it can be difficult to program at times. Have you tested the radio and receiver by themselves? By using a rec pack and some servos? Do you have the same xtals, or the synth set correctly? I would fully test the radio and double check all of the settings first.
06.20.2008, 03:18 PM
I haven't done any programming on the transmitter yet, so I'm guessing it's "stock", except for the reversed servos.
I'm still stupmed and can't find anything helpful on CC's site.
Loa
I like chocolate milk
06.20.2008, 03:34 PM
check your F/R ratio. Try the 70/30 if you are on 50/50.
06.20.2008, 04:59 PM
I had trouble setting up my lazer 6 with the MMM- had to turn down my throttle epa and crank up the brake epa before the esc would calibrate correctly... it might take a bit of fiddling....
06.20.2008, 05:18 PM
Thanks for the help. The problem was the little APL screw on the transmitter. For some reason it was too tight.
Now it's working.
Thing is: I lost a wheel nut on my first drive, in the grass... Right now I'm praying the hardware store has one in the exact right size. :-(
Loa
06.20.2008, 05:27 PM
You lost a nut? That sounds nasty....
I think you need an M4 nut, but I've never actually seen the size written down anywhere- its bigger than M3 at any rate.
Supermaxx
06.20.2008, 07:53 PM
You need an M5 nut.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
06.20.2008, 08:24 PM
Man I know that feeling all too well. Got my hyper going, and then shot a nut off the right rear wheel. Fun over. :(
06.20.2008, 08:48 PM
Hehe... Bad crash, lost a nut. Ouch!
Seriously, I don't have stock wheel hubs. David put some 17mm hexes on it before he sold the roller, so I'm not even sure what I should get to replace it.
Loa
P.S. After all those months of building then waiting for the final parts, I get to drive it 15 seconds... Sheesh!
06.20.2008, 08:59 PM
Loa
I know that feeling all too well...
06.20.2008, 10:58 PM
Hehe... Why do I keep making sentences that have "alternative" meanings! :-)
Loa
06.21.2008, 04:40 PM
This is RC-Monster, its what we do best!
If the hubs are 17mm, then the nut should be 17mm or 16mm, depending on the brand I think.
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
