Revo with centerdiff unloading
miniGranis
Revo with centerdiff unloading - 06.30.2008, 02:38 PM
What can be done with the Revo center diff to keep it from unloading ?
I have tried Kyosho 500K and Ofna diff lock lube, I didnt notice much difference but from what I understand the Ofna diff lock should be thicker.
83gt
06.30.2008, 02:44 PM
Get rid of the center diff. Revo is too heavy in the rear to use it. I tried a while, and took it right back out. Get the FOC instead ;). I did a search and found pretty much the same from everyone. Havn't found anyone yet happy with a center diff in Revo.
J.
azjc
06.30.2008, 02:49 PM
diff lock is as thick as it gets, whats your spur/pinion ratio? I have mine @ 38/18 and mine only gets out ouf contol after about 200 ft of WOT, I have been thinking about putting some lead weight in the front to keep the front end down...maybe about a couple of ozs, I have a CD with 500,000 wt . from what I have heard from other members the Revo CD doesnt do that much
TDC57
TDC57's Avatar
06.30.2008, 09:38 PM
Azjc,
I've got 30,000 in my buggy CD, but you’re running 500,000 (?) Wow...
I'm with 83gt,
Lose the CD on the E-Revo, that a heavy truck and your better off with a G1 single speed tran for $110.
Nothing!.. Hahahahaaa..
azjc
07.01.2008, 02:36 AM
Originally Posted by TDC57 View Post
Azjc,
I'm with 83gt,
the Revo Cd is different than a CD in a buggy,truggy, muggy...the Revo CD comes stock with 100,000 weight..its not that bad maybe if I get bored 1 day I will remove the tranny and put the stock shaft back in
t-rexn8
07.02.2008, 10:41 AM
Is anyone racing with the CD?
BL_WidePede
07.02.2008, 08:56 PM
The whole point of a center diff is to unload the power to the front (to a certain extent). If you want alot of wheelie action and solid power to the front/rear then put the stock shaft back in.
miniGranis
07.03.2008, 05:15 PM
Thanks guys, I take it there are no aftermarket / current mods that will allow for a "proper" (truggy) centerdiff on a std. Revo chassis either ?
intrg8r
07.04.2008, 06:16 PM
I bought this off of eBay. It supposedly is a full 1/8th scale diff for the the Revo. When it arrives, I will follow up with a review.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=160257307023
Check out the other link on the page. I think it is to the guy who made it.
azjc
07.04.2008, 06:27 PM
the link you have is pretty much what the stock revo CD looks like
intrg8r
07.05.2008, 01:15 AM
Nope, the link was to a full 1/8 scale center differential. Look at the size of the cup compared to the gear. The revo diff cup is considerably smaller than the drive gear. This one extends nearly to the edge of the drive gear. I will keep you informed when it arrives.
miniGranis
07.07.2008, 06:41 PM
That 1/8 diff seems to be GiffrinRU's work or am I wrong ?
intrg8r
07.07.2008, 08:44 PM
yes it is. Do you have one?
GriffinRU
07.11.2008, 03:27 PM
No, it is not designed by me. I bought it from (link was attached at ebay auction) cowboy-ray. He did a very nice job with this differential, long time before traxxas even seen the need to make one.
It is true 1/8 scale diff, not like 1/10 traxxas one, and it has nice support for bearings as well.
miniGranis
07.07.2008, 08:49 PM
Nope but I am very interested to hear how it works and what parts are beeing used.
Post back when you get it.
