X2-CRT conversion?
Gallagher
X2-CRT conversion? - 07.22.2008, 11:15 AM
Anyone ever make the conversion of X2-CRT?
How about the brushless central diff mount? Is there any commercial product available or any substitute? Thanks.
jnev
jnev's Avatar
07.22.2008, 02:19 PM
Not sure on the motor mount, but I know that there is a guy on RCTech that converted an X2. It turned out great. I'll try to find the link...
Edit: Post #8717
http://www.rctech.net/forum/showthre...in#post4653506
He is also actually using the Tekno motor mount. I think he just drilled 4 additional holes into the chassis.
ffactory666
07.25.2008, 11:44 PM
Edit: Post #8717
That's my X2 conversion Jnev .
I just drilled and dremeled 4 new slots in the chassis for the Tekno mount so i can adjust gear mesh .
Fits great , only thing because the mount is seperate from the diff ,when the chassis flexes it could stuff up the gear mesh so i braced the centre diff to the rear chassis brace which will stop the centre chassis flex .Pics below so you can see how i braced the diff.
I also have one of Mikes CR buggy mounts coming to try out in the X2
Finnster , the X2 has been run now down here in Australia for nearly two months . I know a couple of guys that have been running it and i think it won the Australian Nats .It has heaps more steering than the X1 , accelerates alot quicker and is holding up great .Flies through the air like an eagle . Also when i built my conversion the driveline was the smoothest i have built
I haven't run mine yet as i fried my MM when testing it out on 5s so i am waiting for the MMM V2 which i back ordered.
ID:	5103   Click image for larger version
ID:	5104   Click image for larger version
Electric Dave
07.22.2008, 09:20 PM
I hope Mike makes a mount. Seems one from the buggy may work if it had a notch drilled out of it to clear that center chassis brace...
I'm debating replacing my 3 year old E-CRT with a X2-CRT but I ain't doing it until Mike has a mount.
07.22.2008, 10:53 PM
Buy the kit and sent it to him and then he can make the mount - someone has to be first...
Finnster
KillaHurtz
Finnster's Avatar
07.23.2008, 10:09 AM
Anyone hear any reviews yet of the new X2? I'm curious how it stacks up and the improvement over the X1.
