esc fried motor?
dpb318
esc fried motor? - 07.29.2008, 01:47 AM
i posted a day or so ago that i smashed two of the three caps on my MM. the MM then proceded to fry my ccbec and caused a ton of cogging. i checked the temp of my 9xl and it read 204 is it possible that the esc fried the motor? or could the high temp have been temporary and will be back to normal (160) with a new MM? this is in a savage on 4s
Electronics
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Electronics - 07.29.2008, 02:32 AM
Sorry to hear that. Electronics are pretty straight forward for the most part. Once you have crossed the upper temperature threashold, you can pretty much count on the fact that the gear will fail. Even if you do get it running again it probably will not last for very long. You may even cause damage to the new ESC, or other components in the process. Once you over temp any electronic compnent it is degregated to some degree and will never operate at full capacity again.
dpb318
07.29.2008, 12:52 PM
well this sucks...maybe i'll get lucky and the motor will still be ok, that would be really nice
Robert
07.29.2008, 01:28 PM
It's a hard lesson but don't run with damged equipment. Get the ESC fixed then try it again.
dpb318
07.29.2008, 03:22 PM
yeah, im not near home so i figured id just run it and see how long it lasted lol...im having a new mm rushed to me (i hope it makes it in time) and just maybe all will work
07.29.2008, 03:25 PM
Well the only question is if you demagnetized the motor - How easy does it turn over. You could always pop the rotor out and check...
dpb318
07.29.2008, 04:37 PM
it turns over pretty easily, it seems to spin normally, how would i go about checking on a 9xl, would i be able to get it back together easily?
dpb318
07.29.2008, 05:16 PM
ok so i was able to pop off the rear end cap and pulled the motor apart. it seems as if the front half of the magnet is magnetized but the rear half is not, is this possible? it seems to spin more freely than it used to...if i spin it hard with two fingers it keeps going on its own for a good 5 turns
07.29.2008, 05:49 PM
Sounds like toast! Need to buy a 9XL? Make me an offer...
I'll throw in a cap ;)
