diff fluid question
dpb318
diff fluid question - 08.09.2008, 07:48 PM
i have a savage with a 9xl on 4s and its running hot. geared 20/52 i have to stop every 5-10 min because im hitting almost 190...does the diff fluid make a difference in heat? im using thick fluid which makes the driving more fun. im running on sand if that helps, would a lighter fluid make any difference? i think its 30000 front and rear
blueb8llz
08.12.2008, 07:51 PM
those xl motor gets hot period. but 190 after 5 mins seems pretty bad. yes running on sand will get the motor hotter quicker. and i dont think diff fliud makes any differernce. i had 30,000 and now i have 85,000 in the front and 50,000 in the rear, and exact same temps.
83gt
08.13.2008, 07:11 AM
If anything you'll have less unloading with the thicker fluid, which should help keep temps lower I'd think. Any difference would be minimal. If there's a center diff, that can make quite a difference though. If it's constantly unloading to the front tires, then the motor can be overworked by constantly revving too high.
J.
