MMMv2 Fan control? Patrick?
RBMike
RBMike's Avatar
MMMv2 Fan control? Patrick? - 08.18.2008, 05:13 PM
I ran it at the track yesterday & put a total of 1 hour of run time on my MMMv2. It ran fine but I'm not sure if the fan is working or not. For the first couple of packs when I brought the car in the fan was running, after that I did not see it run again. With the fan control how do you know the fan is working??? I'm not complaining but I have an concern, If running without the fan voids the warranty and there is no way to know for sure if the fan is working unless you get the MMM hot enough... you see where this is going. If the fan runs all the time then I will know when it is broken thus replacing it & not voiding the warranty. If the fan never runs I will never know if it is broken or my set-up is just too cool for me to see it run.
big greg
08.18.2008, 05:16 PM
a good way to tell is temp it, if its over 140 or so, and no fan, then its not working
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
Turn off the power switch and when you turn it back on the fan will run while the ESC initializes.
RBMike
RBMike's Avatar
08.18.2008, 05:20 PM
Well then My MMMv2 is broken because it does not run (the fan) when I turn it on. Last night when I got home I put a new fan in and it did not run when I turned on the unit so my fan did not die but the fan controller must have. The fan connector looked OK.
JerryF504
JerryF504's Avatar
08.18.2008, 05:22 PM
Originally Posted by RBMike View Post
Well then My MMMv2 is broken because it does not run when I turn it on. Last night when I got home I put a new fan in and it did not run when I turned on the unit so my fan did not die but the fan controller must have. The fan connector looked OK.
That's not good. Mine runs from the time you turn on the switch until all of the tones are finished.
Pdelcast
Pdelcast's Avatar
08.18.2008, 05:38 PM
It only runs during a cold start -- which requires that you have power removed for a few minutes.
The fan controller is designed to run the fan if it fails... so if the controller dies, the fan should run all the time.
Patrick
Patrick del Castillo
President, Principle Engineer
RBMike
RBMike's Avatar
08.18.2008, 05:40 PM
Patrick
Patrick, I think after replacing the fan at home last night, that should qualify as a cold start correct?
RBMike
RBMike's Avatar
08.18.2008, 05:56 PM
Patrick you have a PM.
