Wanted: Dc Power Supply
bustitup
Wanted: Dc Power Supply - 08.30.2008, 09:17 PM
Looking for a good deal cash or trade for a PS for my Hyperion Duo
nickwild@comcast.net
bensf
08.30.2008, 11:13 PM
I converted a Computer power supply for mine. It has been working well. Just started to get to the end of its life now, but I went cheap and only spent 20 bucks on it.
bustitup
08.30.2008, 11:49 PM
I been reading about those......does it have enough amps to operate a hyperion duo? I think they need 15 or 20 amps.....I have an old atx 350 watt atx
cheesecake
08.30.2008, 11:58 PM
http://cgi.ebay.com/ws/eBayISAPI.dll...m=200248366896
i bought that one
bensf
08.31.2008, 01:12 AM
Originally Posted by cheesecake View Post
That is a computer PSU that someone added plugs to, and may have done a few mods on the inside. It should work fine, but you are paying to have them do the mods and not doing them yourself.
Sorry for the double post. . .
bustitup
08.31.2008, 02:14 AM
what you think of this one and how hard is it to convert?...all I would need is two female bannana plugs?
http://www.newegg.com/Product/Produc...82E16817709011
bensf
08.31.2008, 01:09 AM
Take a look at the sticker on the back. It should say how many amps on the 12V rail. I've found the price/performance ratio is much higher with the computer ones than other ones.
This one for example puts out 26A on the 12v rail.
For your charger anything rated at 550W or more should be sufficient. I'm pretty sure that if it has more than one 12V rail you can run the charger off of all of them and not just one.
Sammus
Sammus's Avatar
08.31.2008, 03:00 AM
no you cant parallel multiple 12V rails on a PSU, you will most like ruin it. Find one that has a higher power rating with a single 12V rail.
bensf
08.31.2008, 03:02 AM
What I did to mine:
Cut off all of the connectors
I took it all apart
found the +12V cables and the black ones picked maybe 5 of them and wrapped them around my banana plug on my charger
heatshrink
neatly cut all of the other cables
take the green cable out of the main mobo connector and connect it to one of the black ones.
That acts as the on/off switch, but it also has one on the back.
The wire that is uses for the computer plugs aren't very good and you really need to make sure you attach a lot of them to the banana plugs. I would say 10.
If you want to be able to unplug the charger, just buy some female banana plugs and install them in the side of the case.
Do a Google search for something like "convert computer power supply RC" and you'll find a few nice guides.
Your charger will pull 360 watts right? That means that you want at least 30 amps on the 12v rail. Even then yo may have the voltage drop too much, I would look for one rated for 33-35 amps just to be safe. It also depends on if you are planning on charging both batteries at 180 amps.
Thanks for the clarification on the multiple rails, I thought it might work, but I guess not.
If you don't mind the color, this one looks nice
http://www.newegg.com/Product/Produc...82E16817148005
Or this one for $40 with free shipping
http://www.newegg.com/Product/Produc...82E16817713004
Sammus
Sammus's Avatar
08.31.2008, 04:03 AM
Also, iirc from what I've read (or more correctly, from what BrianG says) most chargers are only about 80% efficient, so to use the full 360W you should be looking at at least a 450W supply - that means nearly 40A on a very stable 12V rail.
Good thing about the hyperion (duo at least) is that you can have up to 28V input, high V low current supplies are much cheaper - maybe even get two PSUs rated to about 19A@12V and run them in series (not sure this will work, but cant think of why it wouldnt). Note that you can not run multiple 12V rails in series, so don't even think about it.
azjc
08.31.2008, 08:40 AM
I dont worry about the chargers maximum power ratings but what the packs will need to draw...I have a Hyperion 0610i charger and its rated @ 250 watts but I only need 120 watts to charge a 6s 5000 pack ...something to keep in mind
bustitup
08.31.2008, 10:21 AM
good point but wouldnt i have to double that because I will be charging two batts at one time?
gimpygolden
gimpygolden's Avatar
08.31.2008, 09:22 AM
I have a ProPeak for sale with a charger,but would be willing to sell just the PS
http://www.rc-monster.com/forum/showthread.php?t=14590
PM sent
"If yer not 1st,yer last"
OFNA GTP w/Quark-Medusa 60mm-5s
Inferno SP2 w/MMM-1512 2.5d-5S
Inferno St-rr w/MMM-1515 1y-5s
bustitup
08.31.2008, 09:53 AM
PM sent
pm returned
bustitup
08.31.2008, 10:59 AM
PM sent
I went with this one...thanks for all the input people
