ofna spider diffs
Semi Pro
Semi Pro's Avatar
ofna spider diffs - 09.25.2008, 04:11 AM
ok so ofna 8 spider center diffs are fairly comon, but i can never find 8 spider front or read diffs for sale
what buggys/truggys did they come in?
can someone help me find afew for my revo
thanks again guys
i may not need 8 spider diffs but its what i want
jordan...
one.five.two.seven
09.25.2008, 04:37 AM
Ebay search: ofna spider diff
F/R 8 Spiders
Semi Pro
Semi Pro's Avatar
09.25.2008, 05:05 AM
thanks, everytime i looked i couldnt find them
neweuser
neweuser's Avatar
09.25.2008, 11:47 AM
You could try "Supermaxx" in Ebay ansd see if any are there. Also UE might have them. The Hyper 7 I believe has 8 spyders. You could look on Ofna website too.
http://www.rcmart.com/catalog/rc-hyp...4aac1b49468c84
this might be one. otherwise it may only be the center diff. i am not that familiar with ofna products.
09.25.2008, 12:26 PM
I have a spare BINB ofna centre spider diff 46T that i bought but don't need...
neweuser
neweuser's Avatar
09.25.2008, 12:34 PM
I think he is looking for front/rear diffs. Can the centers be converted in the actual diffs?
Semi Pro
Semi Pro's Avatar
09.25.2008, 04:10 PM
yep im looking for front/rear diffs
yes center diffs can be converted but the ring gear is not cheap
blueb8llz
09.25.2008, 07:34 PM
heres a few, not sure if they are 6 or 8 spiders tho.
http://cgi.ebay.com/OFNA-87343-Diff-...2em118Q2el1247
http://cgi.ebay.com/OFNA-Ho-Bao-Hype...QQcmdZViewItem
http://cgi.ebay.com/OFNA-HOBAO-HYPER...QQcmdZViewItem
plettenbergs
plettenbergs's Avatar
09.25.2008, 07:52 PM
the black ones are 6spider...the silver one is 8spider...i have those in my UE trucks!!!the hold under dual Plett BigMAXXimums!...they are THE BEEEEF
Duster_360
09.25.2008, 08:25 PM
That looks just like my UE 8 spyder diffs, but it says torsen on box?? If it is, you don't want it for offroad. Is that a mistake, or is it something I'm just not familar with??
George16
Supermaxx
George16's Avatar
09.25.2008, 08:32 PM
The Ofna/Hobao Hyper 7/8/8.5 uses the 8 spiders as an option. I have the parts manual for the hyper 7.
Duster, it's listed as a Torsen but it's not. UE sells the Hyper 7 6 and 8 spider diffs. UE just added the shim kit, bearing, and diff outputs to the hyper diffs . I never bought "UE 6 or 8 spider diffs". I just bought the UE 7.5 diff outputs and installed them on the Hyper diffs. Much cheaper (I get a military discount from UE too). Let em know if you need part number for your diffs (O-rings, 2.6mm screws etc.).
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Duster_360
09.26.2008, 09:27 PM
....Duster, it's listed as a Torsen but it's not. UE sells the Hyper 7 6 and 8 spider diffs. UE just added the shim kit, bearing, and diff outputs to the hyper diffs . I never bought "UE 6 or 8 spider diffs". I just bought the UE 7.5 diff outputs and installed them on the Hyper diffs. Much cheaper (I get a military discount from UE too). Let em know if you need part number for your diffs (O-rings, 2.6mm screws etc.).
I didn't think that could be a true Torsen at that price. You got me set earlier with some ebay links - I have a set of spare 6's and 8's and and nip backup in each. I bought some stuff from Tom Wolf and must have lifetime supply of misc small parts for both 6s and 8s. My UE sets are used ones bought a few yrs back when they were like new. All I've ever had to do was change oil or swap the outputs to run 3.3 axles.
