mamba max shuts down after a jump
kyosho501x
kyosho501x's Avatar
mamba max shuts down after a jump - 09.25.2008, 08:48 PM
why does my mamba max shut donw after a jump. i've only had it for a day. should i put more servo tape underneath?
hyper 8- workin on conversion
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.25.2008, 08:49 PM
Possibly something to do with the switch. Try mounting the switch differently.
kyosho501x
kyosho501x's Avatar
09.25.2008, 08:52 PM
as in how?
nothing is hitting it
brushlessboy16
brushlessboy16's Avatar
09.25.2008, 08:54 PM
or get rid of the swich and tie the wires together. then its on whenever u plug in the batt. less hassle
kyosho501x
kyosho501x's Avatar
09.25.2008, 08:59 PM
i have an extra novak switch so i might use that. i plan on using a switch since i easily forget about disconnecting batteries, that's why i don't have lipo.
tc3_racer_001
tc3_racer_001's Avatar
09.26.2008, 07:41 PM
leaving ANY BATTERY connected will damage it... its just a case of how long. imo they shouldnt have come with switches but thats my opinion of course.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
09.26.2008, 09:52 PM
are you running a external bec?....this happened to me a couple of times until i found the "cold" solder joint where my bec was plugged in....it also happened when i found another "cold" solder joint on my deans plugs.....
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
09.26.2008, 10:18 PM
bad solder joint or is there any of the bullets that aren't completely covered with shrink. If any wires touch each other that could be really bad. Best to eliminate the switch, it only shuts down the internal bec
ren
ren's Avatar
09.27.2008, 12:05 PM
I had this problem with mine and went through all my soldering only to find it was the ESC plug into the reciever pulling out. I put a zip tie on it and it fixed the problem.
