22T Mod1 Pinions -
11.21.2005, 03:56 PM
Does anybody know where I can get a Mod 1 5mm bore 22T pinion? The largest that I can find is a 20T pinion. Thanks.
11.21.2005, 04:32 PM
Those are RARE! perhaps Mike can have you one made? what is the use for that large size?
11.21.2005, 04:34 PM
Best person to ask is Mike,i know he has some 24T stock because he just made me a pinion from it.
11.21.2005, 04:59 PM
I'm using a 54T Spur Gear and a 18T pinion in my Brushless Hyper 7. It has an enormous amount of torque and I would like to see what kind of top-end speed I could obtain by switching to a 20T and 22T pinion. I just ordered the 20T pinion from Mike and it was shipped today, so we'll see how much speed it provides.
Mike,
Could you have a 22T Mod 1 5mm bore pinion made? Also, could it be made using a 3mm set screw instead of 2mm? If so, how much? Thanks.
11.21.2005, 05:04 PM
That's a very high gearing,i think your shulze may be on the endangered species list with the 4-pole bigmaxx on that kind of gearing.Does it not run hot with a 18T?
11.21.2005, 05:31 PM
I'm not sure if it runs hot with the 18T, because the only night that I ran it, was about 29 degrees F. When I was researching the center transmission options, it was recommended to use a 51T spur with a 14T pinion, which is almost the exact same gear ratio as the 65T/18T combination that I'm using. If the gear ratio is the same will the motor have to work harder to spin the 65T/18T combo vs. the 51T/14T combo?
11.21.2005, 05:42 PM
Oh,OK you said 54/18,i thought you were going to go 54/22,couldn't you use a smaller spur instead and use the pinions you already have?
11.21.2005, 05:54 PM
I did make a mistake in my previous post. I'm using a 65T spur gear with a 18T pinion gear.
I'm not aware of any smaller plastic spur gears that will fit on the Ofna Monster Pirate slipper transmission that I'm using.
11.21.2005, 06:01 PM
the 51 fits on as well Takes a little work though, but Ryan did that too on his maxx.
11.21.2005, 11:04 PM
If my current configuration gives me any problems, I'll have my machinist make a custom adapter disc so that I can use the Ofna 51T plastic spur gear.
Site Owner
11.23.2005, 01:22 AM
I will see about some 22 tooth stock. The 20 tooth pinion has a 4mm set screw on it, as all the carbon steel pinions in the store do.
11.23.2005, 01:32 AM
Thanks Mike. The 4mm set screw is perfect. I look forward to seeing the performance with the 20T pinion, and will wait to hear from you concerning the 22T.
Hybrid Mode
