Look at this Slash.WoWWWWWWWWW
david lamontagn
Look at this Slash.WoWWWWWWWWW - 10.26.2008, 06:24 PM
Awsome, i realy like it, and you know what??? I have this tire mount on Ofna half offset wheel and the HPI wing mount too
You know what my slash would look like in a few week?
http://monster.traxxas.com/showthread.php?t=435961
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
10.26.2008, 06:28 PM
Yeah, there is a topic on it here
http://www.rc-monster.com/forum/showthread.php?t=14944
Im tempting to try it out http://www.ultimatetraxxas.com/projects/backslash/
Anyone know if anyone else makes 17mm apaptors as I can't find those new era ones?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
MetalMan
MetalMan's Avatar
10.26.2008, 06:34 PM
http://www.neweramodels.com/item.cgi...=&part_id=8538
david lamontagn
10.26.2008, 06:36 PM
I just order my adapter from new era, i wait for the invoice to pay it.
rootar
rootar's Avatar
10.26.2008, 07:04 PM
the half offsets dont have quite enough clearance, read all the way throguh the thread that drift buggy linked.
IT DEFINETLY helps in the handling and jumping big time, but youll need the full offset wheels to get it to work right without the front tires rubbing alot.....
10.26.2008, 07:09 PM
I am building a version of that too. I have the body and the full offset wheels and the panther tires too. Just need to cut the body and make a wing mount. I have no idea how good it wil be, but the slash was disappointing to me stock...
david lamontagn
10.26.2008, 07:28 PM
I have the half offset here, and i've put it on just to see and it's very good, no rubbing at all
rootar
rootar's Avatar
10.26.2008, 07:45 PM
turn the wheels at all the compress the front shocks...... look at my picture on the 2nd page of that thread that was linked.
asheck
10.26.2008, 07:54 PM
I like mine better :) I call it My big green Stash I just used some Stampede parts that I had with a Slash chassis. But I could not find offset wheels that were wide enough so I had to use the Integy wheel extenders.If anyone knows where to find full offset MT wheels,please let me know. BTW this thing handles pretty good.It's much more comparable to a real MT then I thought it would be.
david lamontagn
10.26.2008, 07:59 PM
Yeh, i've see it too, realy nive!!! can you link me your wheel adapter please??????
But i've a question, your wheel adapters is vvvveeeeeerrrryyy long, this thing could put alot of stress on the bearing
And which wheel and tires you use for it?
Thank you
This one is full offset i think
http://www3.towerhobbies.com/cgi-bin...?&I=LXTVA7&P=7
david lamontagn
10.26.2008, 08:11 PM
I think i've find it, this is this one??
http://www3.towerhobbies.com/cgi-bin...?&I=LXTBP2&P=7
Oufffffffffff, ouch!!!!!!!!!!!!!!!!! the wheel bearing
This wheel extender must put realy, but realy too much stress on the bearing
Do you have to run different offset wheel on front?? Why this adapter is not the same lenght front and rear????????
asheck
10.26.2008, 08:17 PM
Yes they are to long.I will do away with them once I figure the right setup.I put new bearings in it when I built it to see how long they last,after 6 or 7 runs they still seem tight,but only time will tell.The tires wnd wheels are off an XT8,they have 14mm of offset.It's pretty much the exact size as my 3905.I have had a couple issues,the rear brearing carriers broke in 2 bashes,so I used some RPM,s on 3s with the slipper to tight it will twist shafts.But really I very rarely go bashing with a Pede and not stop before it's broke,so I'd say this is close to as reliable. in this vid I ended up stripping a spur,dang motor moved. http://www.youtube.com/watch?v=4xSknqCz-GA But I've bashed it like this about everytime.I have several short vids of it. Stock the Stampede uses different offset wheels,thats why the extenders must be different.I have the wide front that makes them equal length also.
10.26.2008, 08:31 PM
Very cool.
rootar
rootar's Avatar
10.26.2008, 08:29 PM
very cool lookin ascheck!
david yu could get flm extended arms and such but reguardless your gonna go thru wheel bearings faster no matter what when running these big tires....
david lamontagn
10.26.2008, 08:49 PM
Yes you're right, but if i build a buggy with panther Komodo tire, this tire is the same diameter than regular 1/8 scale buggy, and if i compare the weight of this tire, mount on Ofna widht offset wheel with my 2.2 badlands mount on Traxxas nitro rustler wheel, it's only 20g difference /wheel. Not too bad, so i don't think that put more stress on wheel bearing.
