MMM v3 BEC questions
coreyfro
MMM v3 BEC questions - 10.30.2008, 12:43 PM
So, a switching PSU for BEC is, basically, the reason I got the MMM. I want off the shelf ease and minimal components, and MMM gives me power for brains and for mechanics in one nice package.
The BEC appears to run at 5.84v which is damn near perfect for my needs and well within the range I can use for my robo-brain (Basically 5.5v to 9v with anything over 5.5v being spent in heat.)
My questions are:
1. Will voltage ever be programmable like the CC dedicated BEC?
2. What available amperages will the BEC provide at 8, 12, and 24 volts (or approximate voltages.)
My brains will use about 1a.
Picture of brains on slash, which is the PERFECT platform for junior robotics. It's the FIRST RC truck that has space for stuff so we can build OUT instead of UP (which makes most RC robots tippy.)
Not to mention, the slash is tough enough to survive going full speed during a stuck control loop! I'm so happy with the slash.
bruce750i
bruce750i's Avatar
10.30.2008, 12:58 PM
Cue BrianG. action.
10.30.2008, 01:12 PM
Looks like an interesting project! You're right; the Slash is about the only stock vehicle I know of with that much empty space on it.
Originally Posted by coreyfro View Post
...My questions are:
2. What available amperages will the BEC provide at 8, 12, and 24 volts (or approximate voltages.)...
1: As of right now, I would say no. The BEC also supplies at least part of the ESC brains with ~6v power, so any adjustments would have to be tolerated by those other components.
2: Not sure what the current output of the built-in BEC is, but judging by the components used, I'd say around 3A is a safe bet. And since it is a switching BEC, that available amperage is good for all voltages from ~7v up to the max of 25v. BEC efficiency doesn't change all that much with supply voltage - it's the load current that makes it fluctuate. And switchers tend to be most efficient at around 75% of their max current rating from what I've seen.
As far as getting stuck in control loops, you outta put in a manual override so you can use a remote (at least for the testing phase). I can just see people running after an out-of-control Slash trying to catch it!
coreyfro
10.30.2008, 02:33 PM
Ahhhhhhhhh, makes total sense now. OK. if I have any requirements for higher voltage, then I'll use my CC BEC. I just want to keep the number of parts low and simple because this isn't for me, I'm trying to make a simple, standard, cookiecutter robot for RC nerds.
Yeah, I don't have a wireless kill switch yet.
10.30.2008, 02:56 PM
Ahhhhhhhhh, makes total sense now. OK. if I have any requirements for higher voltage, then I'll use my CC BEC...
Depending on the actual voltage you'll need, you can probably get away with using a linear regulator since you said you need ~1A. The loss in efficiency will be less and less as the regulator voltage approaches the supply voltage and/or the current goes down.
The losses is simple to calculate: power_loss = (supply_v - regulator_v) X current.
So, if you are running 4s and wanted 9v out, the loss at 1A would be 5.8w. A decent amount to be sure, but nothing that a medium heatsink couldn't handle. As a bonus, linear regulators can be "programmed" (via 2 resistors) to be at any voltage you want.
The disadvantage of linear regulators is power loss/inefficiency. The disadvantage to a swithing regulator (aside from cost) is the potential for it to go bad and send full supply voltage to your circuits. It doesn't happen very often, but is possible. I don't know how expensive that processor/circuit is, but something to think about. Linear regulators usually fail by thermaling, or going into overload shutdown. You have to really try to blow a linear regulator.
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
10.30.2008, 02:14 PM
I *think* Patrick once said that the MMM's BEC was good for up to 5A, but ran quite warm at that kind of drain. I could be remembering wrongly, though.
Looks like a cool project though! What are you planning to do with it?
coreyfro
10.30.2008, 02:42 PM
I'm working on an off the shelf implementation of another project I (and about 20 of my friends) have worked on.
Orb Swarm is a network of 6 robotic orbs that communicate with each other and choreograph their own movement, music, and light show.
Each orb is about $6000 and MONTHS of work, not including the year and a half of software work...
...With this side project, I'm making swarmable robots accessible so we'll have more robots to swarm with.
I want to make it so any RC nerd unafraid of UNIX can make a swarmable robot out of any of their models, easily.
Imagine your local football field filled with 20 or more rc robots driving around in formation, blinking and chirping together.
Failing that, I'll at least have a software development platform for myself that roughly models the orbs because, at 80lbs and 30", they are a bit too large for my Corolla to haul.
TexasSP
Something, anything, nothing
TexasSP's Avatar
10.30.2008, 02:59 PM
You peaked my interest, now need a video!
www.cubicle101.com
coreyfro
10.30.2008, 03:31 PM
This video is from Sept 2007. It's the best video we have at night.
And here's our Media page
Pdelcast
Pdelcast's Avatar
10.30.2008, 04:34 PM
Did you stop and see Cyclovision while Castle was at Burning Man in 2007?
We did a 6 x 3 foot 3D projection system (picture 10,000 RGB LEDs rotating at 300 miles per hour creating a 1 million voxel viewing volume...) we called Cyclovision. It's still together, but we didn't make it to Burning Man for 2008 ('cause of the Monster issues...)
Patrick del Castillo
President, Principle Engineer
coreyfro
10.30.2008, 05:16 PM
No! I tried to google you with no luck. Are you related to Cubatron?
I think I heard about Cyclovision, but I didn't get to see anything, I was busy working 4 F'N PROJECTS!
Steampunk tree house (I did a bunch of CNC plasma cutting for it, and helped with roll out but not setup)
Orb Swarm (I was the Playa Proof Puter/mothernode guru during the event)
Neverwas Haul (mainly my wife's project, but I hang out with them because they are serious about relaxing.)
Critically Single (Speed dating on wheels...don't ask)
I haven't simply ENJOYED the event in 4 years...and I've loved every minute of it.
Have you been to the Maker Faires? If not, you should go, especially since the sheer number of robotics nerds there is staggering and would probably be great bidness for CC.
I'm sure the voxel display would be great at maker faire, too.
I saw a bunch of CC signs at Robogames but I didn't see a booth.
Damn Monster!
Pdelcast
Pdelcast's Avatar
10.30.2008, 05:59 PM
Damn Monster!
Loved the Steampunk Treehouse! Richard and Jon and I look for the Orb Swarm the whole time we were there -- was one of the things we really wanted to see. . . but never caught it. My wife saw something similar (robot dogs that protected a camp area -- was pretty cool...) but I missed it...
Here's some pictures of Cyclovision (Sorry -- I don't mean to 'jack your thread!)
Cyclovision being put together on the Playa: (Look close and you can see the FPGAs and LEDs -- There is also 128GB of memory in the stack -- yes 128 GIGAbytes -- all the animation was stored in Flash)
(The fat guy is me...)
And some bad shots of some of the play: (1000 RPM rotation -- 3D images)
Synthia:
Animated Fireworks:
