Monster Max Mounting????
lwracer
Monster Max Mounting???? - 11.10.2008, 11:16 PM
Anybody else have a problem securing the Monster down with double sided tape?
We are using 3m quality tape ...but it does not seem to stick to the bottom of the Monster......
Any suggestions?
Thanks!
11.10.2008, 11:17 PM
Did you remove the sticker first?
lwracer
11.10.2008, 11:19 PM
We did remove it ....did not seem to help though......
Cartwheels
11.10.2008, 11:25 PM
I always use velcro on both surfaces for easy removal and then use a zip tie to keep there.
11.10.2008, 11:27 PM
Did you clean off the old sticky residue? I use lighter fluid to get the goo off, then denatured alcohol to clean the lighter fluid off.
Some adhesives seem to need a few minutes to bond right. I use velcro and if I don't let the velcro sit for a few minutes, it tends to come off before the velcro lets go. But, if I give it about 20 minutes, it's on there quite solid.
lwracer
11.10.2008, 11:29 PM
We did end up using the tie wrap but that looks like crap!
Thanks!
lwracer
11.10.2008, 11:30 PM
Ok...Thanks!
RBMike
RBMike's Avatar
11.11.2008, 02:04 AM
Yes the tie wrap looks like crap but the tape or the velcro are not enough in a bad crash.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.11.2008, 03:57 AM
Originally Posted by mkrusedc View Post
All I use is zip ties. They have withstood 30 ft cartwheels:
A chassis like that just begs you to use zip-ties!!
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.11.2008, 02:08 AM
jnev
jnev's Avatar
11.11.2008, 02:14 AM
Velcro seems to work very well for me. And then a zip tie around the ESC and another object secured to the chassis. This method has held up flawlessly through countless hours of running.
marzac2
marzac2's Avatar
11.11.2008, 04:30 AM
Traxxas is coming out with a molded plastic "hold down" part in a bit made for the MMM and it will end up being the best solution to this problem. It screws down on the ESC and seems like it will safely hold it through most all crashes.
Losi 8 Buggy + Truggy & Associated SC8
Tekno RC Conversion Kits on all
MMM, MGM, Xcelorin ESC's
Tekno Neu "square can" brushless motors
Polyquest - Neu - Flight Power LiPo's
Smashwings
Smashwings's Avatar
11.11.2008, 02:51 PM
I've seen it in the photos of the new E-Revo brushless, but not for selling online yet. Hope it will be released soon (but I think we will have to wait till Brushless E-Revo is released)
auto2
11.11.2008, 08:54 AM
i use velcro and 1 zip tie. i mounted it on a "table" that screws to the chassis so I can get a zip tie around it. it is not "clamped" down. with the velcro it can move around a little but never comes loose. i would be really interested to see what traxxas comes up with like a whole new case that bolts down and is water proof:-)
macr0w
macr0w's Avatar
11.11.2008, 09:42 AM
I use velcro to hold the bottom of the case to the chassis/mount.
But I use a zip tie to hold the rest of the MMM to the bottom of the case.
