ĄGo Baby Go!
MBX Pro Conversion -
12.03.2005, 12:38 AM
Well, I finally made the plunge and am purchasing a rolling chassis off ebay. I know how to get the conversion done and have planed it all out, I'm just lost on this whole diff oil deal, I bash mostly, so I just want them to hold up.
As for a setup im planning on running 12 gp 3700 cells
For motors, either a Basic 2400xl or Wanderer 10 L. Not sure which would be better, but my current controller is an MGM 80, which is risking it with the 2400xl and not enough for the 10L.
Also, is the JR z590M or Hitec 645mg bb a good servo to run for steering? They are sick in 1/10th's, but maybe not enough.
RC18T FT - Quark Castle Creations Airtronics IB
12.03.2005, 11:14 AM
I don't even use a center diff on my 1/8 buggy :). I built myself a slipper clutch using Revo parts.
The 10L would probably be a better motor for a 1/8 buggy. It should be fine with the MGM 80amp controller, but if the controller got too hot, you could always put a fan over it.
The 645mg would work well. You need ~100 oz./in. of torque for a buggy.
12.03.2005, 11:29 AM
Have you already purchased the buggy? I've been contemplating selling the MBX I have as well.
Even bashing, you're definitely going to be pushing the buggy to more than I would trust the MGM 8012. You should consider the 12012, 16016, or the BK 9920/12020 for the best experience.
I agree with MetalMan that 100oz will be good for a bashing servo.
Good luck with the conversion!
Joe
12.03.2005, 01:00 PM
Right now I am using a controller rated at 80amps continuous, with a Feigao 540C 9L (similar to 9L). On 12 cells, everything stays pretty cool (under 120 deg.). Same thing with 4s Lipo.
12.03.2005, 03:35 PM
i would go for a 8xl or maybe a 7xl. that will provide plenty of torque and will run cool in a buggy. coolhand has run a 9xl on a 7020 so i would assume a 9xl on 12 cells with proper gearing would be safe on the 8012.
-corey
ĄGo Baby Go!
12.03.2005, 11:02 PM
Not looking to run an XL motor, extra weight does not exactly convert over to extra power. And I have already purchased the buggy :-\, may I ask why you are selling yours? I'd like to run the 10L, but we'll see how the controller situation works out.
Still looking for suggestions on the diff oil
12.04.2005, 09:55 AM
try 10 k or 5 k to start on the center diff. I can not say for sure
12.04.2005, 12:03 PM
As far as diff oil, I prefer the opposite of most setups. I like thicker oil in the rear and lighter in the front. My last setup with a Hyper 7 had 3k front, 5k center, 7k rear.
I'll be selling my MBX stuff in an effort to get a vehicle higher up on the racing scale, as I'll only be racing with it. Not sure what vehicle it will be yet, but it's probably not going to be the MBX.
Joe
ĄGo Baby Go!
12.04.2005, 12:09 PM
Alright, I'll get a range of oils, but its looks like 5k for sure in the middle. Any harm in going the same oil all around? I've never owned a 1/8th, but I used to own a xxx-4. Hoping to get more ground clearance and grunt than the little xxx-4.
Now all I need to do is sell my mf1 and Basic 4200 / MGM 80 to raise a little funds for the project.
12.04.2005, 02:35 PM
If you need any parts machined you should contact Andrew over at Cold Fusion Racing. He has done amazing quaility for me, and It will make any project look 1 million times better then chopped up parts.
ĄGo Baby Go!
12.07.2005, 06:08 PM
Well, the roller got here today.
From the looks of things it'll need a new chassis, stainless steel screw set and some tlc. Other than that it looks great for $100. I was surprised with the size, battery mounting shouldn't be any trouble at all with 6 cells.
12.07.2005, 07:07 PM
I took my buggy for a spin this morning and last night. I have 10 k center with 5k front and back. It seems to be pretty good. I am running a 7xl on my buggy. I tested it with 12 and plan on going with 12-16. I will have to let you know upon further testing.
12.07.2005, 11:09 PM
What is wrong with the chassis?
ĄGo Baby Go!
12.08.2005, 05:34 PM
Its overly scratched up on the bottom and has some residue on it i don't feel like messing with.
ĄGo Baby Go!
12.26.2005, 06:42 PM
Here's where the conversion is at now
Hybrid Mode
