Novak 4mm Connectors?
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
Novak 4mm Connectors? - 11.27.2008, 05:56 AM
I am running a MMM ESC, Neu 1512 2.5D and 5S Battery. Is 4mm connectors going to be fine? I notice that the Tekno motors come with 4mm connectors.
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
MetalMan
MetalMan's Avatar
11.27.2008, 04:11 PM
4mm connectors are a bit small IMO, I prefer either direct soldering or the 6.5mm connectors CC uses. I haven't tried any of the 5, 5.5, or 6mm connectors out there.
DRIFT_BUGGY
11.27.2008, 04:26 PM
I was currently using direct soldering but when I require to pull apart and clean the motor I have to unsolder and then solder back. I was looking at the 6.5mm but alot of people said there overkill and then I noticed that the Tekno motors come with 4mm connectors
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
Daytona675
11.27.2008, 05:06 PM
Wire Gauge:
4.0mm: 16-13ga
5.5mm: 13-10ga
6.5mm: 13-8ga
Max Amps:
4.0mm: 75 amps
5.5mm: 150 amps
6.5mm: 200 amps
This is on Castle website. Don't know what Novak rates theres at but they ought to be close.
rootar
rootar's Avatar
11.28.2008, 11:55 AM
from experience the 2.5d would be fine with 4mm, thats what i put on my 1512 3d, they dont get warm and neither do 4mm on the 2.5d i used to run 4mm on my 1515 2.5d and they didnt get warm.... my battery was only rated for what the plugs were so if the plugs started to get hot i knew i was pushing my battery.
DRIFT_BUGGY
11.28.2008, 05:45 PM
Yeah, I might give them a go and just monitor the temps. What should be the hottest they run?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
11.28.2008, 10:00 PM
I've had my connections go to 145.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
11.29.2008, 11:17 PM
That sounds like a bad joint but it can also be the heat coming from the motor or speedy.
