cc bec....WTH!
stompingpede
cc bec....WTH! - 11.29.2008, 06:47 PM
so irun the cc bec to power my reciver, whlie running it i bring it in to check the temps. and i notice the negative wire from the bec became un soiderd, BUT it still works.green light is on and still powering my reciver...WHAT!!!! i imagine this cant be good and i hope i didn't mess any thing up
Matthew_Armeni
Matthew_Armeni's Avatar
11.29.2008, 07:09 PM
Yup, it's fine. That's how I run mine all the time.
  Send a message via AIM to Matthew_Armeni
11.29.2008, 07:12 PM
The BEC, rx, ESC, and batts share a common ground, so if the BEC ground lifted, the system was most likely getting it through the throttle and ESC ground.
11.29.2008, 07:38 PM
I had the same problem, but it was with my POSITIVE wire. WTF? It worked too...
11.30.2008, 12:26 AM
Huh? I don't have an explanation for that unless your ESC BEC was still hooked up...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.29.2008, 08:45 PM
I had the same problem, but it was BOTH wires! It still worked! Kidding.....
bdebde
That's All Folks!
bdebde's Avatar
11.30.2008, 12:17 AM
I don't even have one... and it worked!
