Hybrid bulks and Supermaxx susp. Slight binding
JAILBIRD
Hybrid bulks and Supermaxx susp. Slight binding - 12.01.2008, 08:57 PM
I am installing the FLM hybrid bulks into my Maxx and using a Supermaxx EXT suspention. The lower arms are tight so I know I need to do some fileing. Should I file the bulks or the arms? My thought was to file the bulks because I can always buy another set for pretty cheap, the Supermaxx stuff is getting harder to find and carries a higher pricetag. Is my thinking correct? Thanks for any help!
-JB
plettenbergs
plettenbergs's Avatar
12.01.2008, 09:25 PM
i would "lightly" sand the arms!
it is very normal to file/lightly sand UE arms to make them fit bulks!
the sanding will not show,they rub together under normal use anyway!
hey JAILBIRD the chassis are coming!!!
TDC57
TDC57's Avatar
12.02.2008, 10:28 PM
I don’t know if this will help but this is how I had to modify my GorillaMaxx arms to fit into my FLM hybrid bulks.. If not sorry Sir!..
Shaun.
And this how it all turned out!
Nothing!.. Hahahahaaa..
