new project..
timaneli
new project.. - 12.12.2008, 02:48 PM
hello.
i have bought a hobbywing 80a esc that works from 2 to 4s lipo and i want to use it on a e-revo..
what motor should i buy for this esc and what lipos do you advise me to use too??
Specification
1.1 Output: Continuous current 80A, burst current 270A.
1.2 Input: 6-12 cells NiMH/NiCd or 2-4 cells LiPo.
1.3 BEC Output: 5.75V/3A (Switch mode built-in BEC).
1.4 Resistance: 0.0018 Ohm.
1.5 Motor Supported: Sensorless and sensored brushless motors
1.6 Suitable Brushless Motor: 8T and > 8T
1.7 Suitable Car: 1/8 on-road or off-road cars / trucks for sportful race and RTR application.
1.8 Size: 68mm(L) * 55mm(W) * 45mm(H).
1.9 Weight: 150g(Without wires)
2 Features
1.1 Compatible with all sensorless brushless motors and most of sensored brushless motors such as Novak, LRP and Feigao, etc.
1.2 Excellent start-up, acceleration and linearity features.
1.3 3 running modes (Forward only with brake, Forward/Reverse with brake, Forward/Reverse immediately)
1.4 4 steps of maximum reverse force adjustment.
1.5 Proportional ABS brake function with 4 steps of maximum brake force adjustment, 8 steps of drag-brake force adjustment and 4 steps of initial brake force adjustment.
1.6 9 start modes (Also called “Punch”) from “very soft (Level 1)” to “very aggressive (Level 9)”.
1.7 Multiple protection features: Low voltage cut-off protection / Over-heat protection / Throttle signal loss protection / Motor blocked protection.
1.8 8 steps of timing adjustment by software.
1.9 Built-in switch mode BEC has a powerful output to supply all the electronic equipments.
1.10 Easily program with only one button and compatible with pocket-sized Program Card.
1.11 Firmware can be updated through an USB adapter (Optional equipment).
1.12 Splash proof and dustproof
http://img399.imageshack.us/img399/2...ing80a1ap1.jpg
http://img88.imageshack.us/img88/351...zrun80eaa0.jpg
regards
12.12.2008, 03:18 PM
sell it, get an mm with external bec and a feigao 8xl on zippy 2s 5000's in parallel for 4s. the best bang for your buck out there
redshift
RC-Monster Square Tube
redshift's Avatar
12.12.2008, 04:23 PM
Paralyzed, could you post a link to the Zippy 2S 5000 packs? I cannot find them on Hobbycity, am I looking in the wrong place?
I did find the Rhino 2S 4900 packs for $40 each and I am tempted, can anyone give me a good reason not to........ I heard they are the same as Zippy.
12.12.2008, 04:40 PM
I meant a pack like that. buy the rhinos you'll be happy
Do you mean two of the 4s 5000's in parallel? Two 2s in parallel is still 2s. I did not see any 2s 5000mah ones either.
I meant 2 2s in series, my bad
Try the hobbywing with an 8xl on 4s, gear for about 40 and watch temps...
Carraig042
12.12.2008, 04:36 PM
-Brett
redshift
redshift's Avatar
12.12.2008, 04:50 PM
Great paralyzed, thanks!
12.12.2008, 04:51 PM
timaneli
12.12.2008, 04:57 PM
were can i found these lipo´s?
can you send me the link please?
regards
12.13.2008, 12:39 AM
regards
ask and ye shall receive: http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack
timaneli
12.15.2008, 03:50 PM
what other motors with 3.17 mm shaft are good for this combination and to work on this 80a esc??
and what stores sell it?
regards again!!
12.15.2008, 04:52 PM
lately i've seen the feigao xl motors on ebay with 3.17mm shafts, if it were me i would get a 5mm shaft, and use nitro revo spur gears, they are mod1 then you can use 5mm mod1 pinions
timaneli
12.15.2008, 05:30 PM
can i use a 7xl working good with this esc too?
12.15.2008, 05:45 PM
7XL will pull over 100amps - I suspect that ESC will be toast
timaneli
12.15.2008, 05:48 PM
so what motor to do i choose without pull more then 80a?
feigao are out of stock here in rc monster store, and from medusa any pull less then 80a?
regards
