Lipo sacks -
12.28.2008, 12:36 AM
Hi everyone, When charging two lipos, should I buy two seperate lipo sacks to charge them in? Or charge both lipos in one sack?
12.28.2008, 12:44 AM
in all honesty i think a ammo case from the surplus store works fine....maybe even better. They are about $10 at my local shop
No Pistons
12.28.2008, 02:50 AM
One lipo sack for each battery. Ammo boxes are NOT safe when things go "wrong".
12.28.2008, 11:46 AM
can you explain how an ammo case does not work?
12.28.2008, 01:26 PM
X2 - My ammo boxes are going to hold up to much more than any of those lipo sacks.
No Pistons
12.29.2008, 01:18 AM
It is the same principal as letting a firecracker go off in your "closed fist". The ammo box will not give and so the energy will not disipate. Same holds true for fire safes.
Have you guys seen a vid of a lipo sack in action? It totally puffs up (contains the flames) and allows it to vent (just smoke) safely.
For all the money we spend on Lipo, BL, etc. this is good money to spend on safety. By the way I am in no way connected with this company.
In fact if anyone knows where to get a good deal on them I would appreciate it. I need to get two.
12.28.2008, 08:30 AM
ya, one in each cuz if theyre in the same sack n 1 pack goes boom, the other one is at risk of doing the same even if theres nothing wrong with it
Check out my FS thread in the General Discussion!! Help me go lipoly!!!
Supermaxx
12.29.2008, 02:03 AM
That's why I drilled some holes on my ammo box. One hole is big enough for the connectors to go through. The holes will dissipate the smoke letting off the pressure and preventing the box in becoming a sharpnel.
Best of all, the ammo boxes were free. I got them from the shooting range on base.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
RC-Monster RC8T
12.29.2008, 02:37 AM
I have a lipo sack and honestly don't use it for charging! If I noticed damage to the pack I just wouldn't charge it. Charging a Lipo with a balancer is pretty safe as long as the pack isn't damaged. I store my Lipos in the sack, and honestly I usually have a couple that aren't in it. Call me a ignorant but I just don't see anything happening to packs that are in good condition!
12.29.2008, 02:47 AM
well revo I wasnt going to go there, I thought stuff on the net being sort of in concrete should be good advise LOL, I never use a lipo sack, I rest them on top of them as I paid $40 for them, if I get around to it, but id rather watch the puppy puff. I only charge my lipos when im close though, as I blew up a 7 cell maxamp NIMH pack that scared the crap out of me. Since I bought the 0610I duo and a 36a I have never had a blip or .02v off charge. Ignorant maybe but i do have those lipo sacks close to use as pot holders if crap happens, but in over 400 combined charges ive not had a fart
12.29.2008, 03:01 AM
that too, i am ignorant in that i have the hyperion 0610i and 25 amp power supply (radio shack but iv'e heard its actually made by a good company forgot which one lol heard it hear though) i spent the money for a tiny bit of peace and mind. i know its not a garantee but it helps. i am also in the room when i charge, as my tiny apt does not let me leave the room
from my understanding you have to MAKE lipos blow up. still from my understandig
RC-Monster RC8T
12.29.2008, 03:03 AM
So many paranoid people out there! Honestly a little common sense goes a long way with Lipos. If it's damaged simply don't charge it and always use a balancer!
WARNING: May become violent.
12.29.2008, 03:25 AM
Lipo sacks are for pansy's...  Theirs nothing to be worried about when charging a lipo unless your a complete idiotic moron who cant read a manual on how to charge a lipo, then you've got some issues... But seriously, lipo sacks serve no purpose if you know what your doing. Plus Ive heard of cases were lipo sacks have failed on larger packs.
RIP- Tammy (9/14/08)
12.29.2008, 03:33 AM
I have $80 of lipo sacks, $1200 of Neuenergey 30c lipos an some really shady ones ive bought off ebay. I have never had a lipo puff, spark or fart while charing with the 061iduo, If you have a bag of sand or charge them in in an ammo can or or home made bomb lipo shelter, I agree you shouldn't be messing with these in the 1st place LOL
12.29.2008, 03:39 AM
I don't think it matters what you use to charge lipos in as long as the following guidlines are met:
> Container should absorb a flame up, not contain it. There should be breathing holes to vent the pressure.
> Container is non-conductive. If the wires happen to touch a metal object at the same time, it could CAUSE a problem. This may be true if there are holes drilled and the wire insulation chafes.
> Container should be able to dissipate enough heat, or insulate the heat, in a flame up to not catch fire to whatever it is sitting on.
Hybrid Mode
