My latest project "X"
My latest project "X" - 01.04.2009, 06:57 AM
Not going to say much about this project, just going to post pics as I go. No prizes will be awarded to those who guess what I am doing, and I will not verify if anyone is correct or incorrect...
pedeboi364
01.04.2009, 09:31 AM
bl solid axle crawler or pro 2 truck with rear 4 link and solid axle... y do i think its a solid axle?? no, rly, idk
Check out my FS thread in the General Discussion!! Help me go lipoly!!!
tt-01 mamba
01.04.2009, 03:26 PM
oooo
somethings gonna be bigger than 4wd i thinks.
Where did ytou get it?
01.04.2009, 04:26 PM
Originally Posted by tt-01 mamba View Post
oooo
I made it, with my plastic welder...
01.04.2009, 04:33 PM
Something maxx-related with more than 4 wheels.
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
02.13.2009, 10:40 AM
I'm wondering how hard it is to learn to use one of those things, I'm thinking that it would be nice to make the battery compartments of the ERevo a little bigger to accommodate some 4s or 5s batteries in parallel. Many of the packs I see on the web are a little too large to fit. I'd love to be able to make the battery compartment up to 10 mm taller and maybe 1 or 2 mm wider. Do you have a good plastic welder to recommend?
Thanks
No brain, no headaches.
More progress with pics!!!
More progress with pics!!! - 03.28.2009, 04:38 PM
Ok, did some more work today on the "Project X" , which will be a 6x6 lst based truck.
1st up was removing the stock steering setup and replacing it with a muggy system. This cures a bunch of problems for me. I am not fond of dual servo steering setups, and the lst setup with the servo mounted savers is a bit sloppy under power with large tires. The muggy setup has a std 1/8 style bellcrank mounted servo saver, and a very solid tiebar holding the cranks together. Plus the muggy has basically the same bulkhead and suspnsion setup as the lst, so the geometry and tierods are all correct. I will have to make a new chassis plate for the truck, as the steering servo will not fit in either of the stock locations. I plan to turn it 90 deg from stock and place it just behind the current servo holes. This will allow for a short link between the servo arm and the bellcrank.
2nd was to fit the pass thru diff into the rear bulkhead. This was very simple. I just removed the rear bumper and rear bulkhead support and repaced it with a muggy front bulkhead support. This is the part that sits on the back of the front bulkhead on the muggy, just in front of the steering posts. It fits perfectly, and has a support for the nose of the diff that points rearward. So the pass the diff is fully supported on both ends, so I doubt that I will have any issues with it. I need to make something like this for the maxx 6x6, as the rearward pointing nose of the pass thru diff is currently not supported...
The driveshaft that will connect the pass thru diff to the rear diff is just a lst1 wheel shaft with the cvd cup of a center driveshaft on it. I am using an ofna hyper8 diff cup to accept the dogbone end of that driveshaft. Pretty simple, and the parts are off the shelf, a big plus IMO! i planned to use a lst2/muggy wheel driveshaft, but the ball end of the shaft is bigger the center driveshaft cvd cup. Luckily the lst1 wheel cvd shaft fits with no mods.
The rear suspension assembly is off my muggy, just using it to mock up what I need to order. It is completely stock, nothing modded save for the addition of the ofna drive cup. I plan to use lst shocks all around, and put the muggy back together... i have almost all of the parts needed to build another bulkhead setup.
Power system will be a hacker c50 11xl on 6s lipo with a MMM. I modded the tranny to forward only, but retained the manually actuated high/low gearset. That way I can have a normal high gear for bashing, and then switch into low gear for some crawling/climbing. Going to run 6 moab 40 series tires (not the xl) on beadlocks. Gearing will be for around 35 mph in high and whatever I end up with in low. Braking will be via the MMM, no mech brakes for me!
I still have to make the extended rear skidplate and upper brace. These will tie the rear and center suspension assemblies together. I also plan to use a set of the muggy chassis braces to tie it together diagonally. I may also make some side supports out of thick plastic to tie the skid and upper brace together and form a box section. I plan to bash this truck, and jump it, so I want it strong.
Time to go to the hardware store and pick up a new blade for the bandsaw, so that I can cut the 6061 al sheet that I just received. Here the pics, the wheelbase is 23" !!!!!!! So this beast will be big!
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.04.2009, 03:33 PM
lst based 6x6
George16
Supermaxx
George16's Avatar
01.05.2009, 12:03 AM
lst based 6x6
I agree. Here's the thread which shows the same diff .
http://www.rc-monster.com/forum/showthread.php?t=16029
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.05.2009, 12:08 AM
[QUOTE=George16;248644]I agree. Here's the thread which shows the same diff
Actually they aren't the same diffs. That was for his Maxx based 6x6 which we all know about. If you have followed linc's threads/posts lately he has talked about a lst based 6x6, I beleive it was in the winter project thread but I don't remember the specifics on his plans.
01.05.2009, 12:26 AM
People do listen... Nice to know!
01.05.2009, 12:27 AM
We do? I wasn't paying attention.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.05.2009, 12:30 AM
I try! Seems like I spend at least 2 hours a day on here reading, if not more esspecially the last couple weeks with so much time off of work for the holidays. Not much better to do for a single guy than sit on the compouter all day
TexasSP
Something, anything, nothing
TexasSP's Avatar
01.04.2009, 05:07 PM
A new and improved butler monkey!
I have been waiting for this one!!!
www.cubicle101.com
01.04.2009, 05:32 PM
I wish those were an available option somewhere. I have a project where a "pass through" diff case would be handy.
