MMM hold down part number
brushlessboy16
brushlessboy16's Avatar
MMM hold down part number - 01.05.2009, 07:57 PM
5626 Mounting plate, electronic speed control (Castle Creations Mamba
Monster brushless system) .................................................. . $3.00
Traxxas finally put up the parts list for the BL e-revo
mkrusedc
NeuMaxx
mkrusedc's Avatar
01.05.2009, 10:39 PM
About time. Anybody know if that means they are shipping?
Takedown
WARNING: May become violent.
Takedown's Avatar
01.05.2009, 10:42 PM
Does traxxas not know what strong DBL sided tape is our are they illiterate....
RIP- Tammy (9/14/08)
01.05.2009, 10:52 PM
If you get any dirt or dust between the esc and the tape it no longer sticks. I will be buying one of these mounts when they come out.
marzac2
marzac2's Avatar
01.06.2009, 03:38 AM
Sometimes if you only rely on double sided tape from below, the case actually can come apart during a hard impact. This can lead to more catastrophic damage as an un-cased circuit board would be flopping around your vehicles inside and you might not realize it.
This is why many people use zip-ties around the top of the case to HOLD everything together.
This is exactly what Traxxas did.
It is a very smart part to make for another manufacturers ESC and addresses the issue while looking custom. A+ Traxxas.
Losi 8 Buggy + Truggy & Associated SC8
Tekno RC Conversion Kits on all
MMM, MGM, Xcelorin ESC's
Tekno Neu "square can" brushless motors
Polyquest - Neu - Flight Power LiPo's
brushlessboy16
01.05.2009, 10:56 PM
Likewise, I ended up Ca'ing velcro to to the bottom of the mmm case.
Takedown
Takedown's Avatar
01.05.2009, 11:05 PM
I never had lucky with velcro... The dbl sided tape I use is a the strongest stuff I can get locally. 5lb scotch heavy duty no residue tape.
brushlessboy16
01.05.2009, 11:11 PM
20lb per sq in velcro works :)
jhautz
jhautz's Avatar
01.05.2009, 11:49 PM
3M Dual Lock. Best stuff on the planet.
to make it...
or break it...
Silent...But Deadly
01.06.2009, 12:15 AM
zip ties. period.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
01.06.2009, 03:43 AM
I second that. I really like the "snap" it makes when it comes together. That's the only thing I don't like about Velcro, sometimes it doesn't stick right.
brushlessboy16
01.06.2009, 08:04 AM
Just realized that what I have IS dual lock- stuff is great!
01.06.2009, 09:45 AM
Only problem is that if you get dirt or dust in the sticky side it never will work again.
What's_nitro?
01.06.2009, 01:37 PM
Well that goes for everything except Zip-ties. But Zip-ties are usually one-time use.
bruce750i
bruce750i's Avatar
01.06.2009, 05:15 PM
To get my double sided tape to stick good to the Rustlers esc mount, I cleaned the mount, then covered it with some aluminum tape, then I put the DS tape on top of that. I use three-four layers of of double sided foam tape stuck to each other, it helps with shock absorption and it seems to multiply the holding power while being more flexible.
