Need help making a motor mount..
brushlessboy16
brushlessboy16's Avatar
Need help making a motor mount.. - 01.20.2009, 09:49 PM
Hello all,
Im trying to make a new motor mount for my Cen matrix tr, Im getting way too much flex from my Al Angle mount. The problem is that as the motor spins, the pinion rides up on the spur, forcing the mount to bend... its eating my pinion right now.. I think my only option is to build a mount off the center diff. I just got 3 feet 1/8th x 2in flatstock from Eovnu87435ds so i have plenty to work with.
is 1/8th thickness too little for a motor mount?
and does anyone have pictures of there home made motor mounts?
Thanks, Ben
Metallover
RC-Monster Spudgunner
Metallover's Avatar
01.20.2009, 10:32 PM
Make a thicker mount out of angle stock. What size are you using now? I think 1/8"+ wouldn't flex.
lutach
lutach's Avatar
01.20.2009, 10:45 PM
Would this work?
http://www.rc-monster.com/proddetail...od=rcmcenmount
brushlessboy16
It would but i dont have that kind of money
lutach
lutach's Avatar
01.20.2009, 10:53 PM
You can't be serious?
brushlessboy16
thats what i have now... and it flexes wayy too much, i even went as far as adding a gusset to it.... still 5mm+ of flex on the top of the mount
Metallover
Metallover's Avatar
01.20.2009, 10:48 PM
Try to make a brace that goes from the top corner to the bottom corner on the same side if it fits. What kind of metal is it?
01.20.2009, 10:52 PM
Email mike he has some "seconds" that are marked up - he might have a cen one...
Metallover
Metallover's Avatar
01.20.2009, 10:54 PM
We teenagers aren't made of money you know.... And besides, if you can make it work for free you'll feel better knowing you saved 45 bucks.
brushlessboy16
01.20.2009, 11:03 PM
i did that(gusset), still bends, its aluminum.
I tried that multiple times, no email responce
Im 16 with no job, i am indeed serious.
Thats the spirit :)
Metallover
Metallover's Avatar
01.20.2009, 11:21 PM
Only thing I can say is try using a stronger metal. Ive got a 3 1/4" x 3 1/2 beast of a plate if you want it. It's pretty heavy, but I'm sure you could get it pretty light in a night of grindin.
It sure as hell won't bend... I got it for a go-kart project but that came apart in the end. BTW it's STEEL. It really reacts to a 130lb neodymium magnet...
B4maz
01.21.2009, 01:54 AM
Hello all,
Thanks, Ben
I used 1/4" aluminum for my motor mount for my Neu 2215 and it works great:
ID:	6263   Click image for larger version
bensf
01.21.2009, 02:29 AM
.125 thick is enough. Its doing doing fine in my revo with a maxx transmission.
florianz
01.21.2009, 04:38 AM
hey,
I understand your problem. Do it my way, I don't own a cnc drill or too.
the mount ist connectet to the diff whith some layers of carbonfiber and glassfiber, some leftovers. glassfiber/gfk is much stiffer than alu, but easy to work with (drill, saw). I glued it together with some good 2k-epoxy. just take some gfk (glass-fiber composite), its bloody cheap. cfk has the better looks, but it 's very hard, that means it "eats" drills and saw blades.
the mount is connected to the chassis as well with a piece of aluminium, the relatively thin quality is easy to handle with normal tools.
this mount is quite "different", but like that it was easy to get it done with my old drill etc. and I have to say, it's stiffer then my other mount for the kb45xl, made of alu. there is no flex at all. and its lightweight.
Metallover
Metallover's Avatar
01.21.2009, 09:10 AM
I have a flat peices of the 1/4" metal too...
