Actual ratio for the flux tranny... -
02.21.2009, 11:13 PM
So what is it?
Looking like the gears, top shaft is 18t, center idler is 44.
Now the other 2 gears are 29 and 32t, but which is which?
So it is either 2.21 or 2.697...
02.21.2009, 11:21 PM
Yeah, I'd like to know how that works too. Maybe someone with a Flux in hand would be nice enough to open up the tranny and post pics and tooth counts...
02.21.2009, 11:34 PM
Ok, p/n for the gear that shares the shaft with the 44t gear is 86084, which is listed on tower to have 32t.
So the output gear is p/n 86098, 29t.
So the ratio is 18/44, and 32/29, so 2.44 and 0.906
That should be a total of 2.214... If I got my math right.
02.22.2009, 12:08 AM
Ok hear it is STOCK: (######) = HPI part numbers.
The pinion gear on the motor is a 20T(100919) which drives the spur gear which is a 44T(102093) for a ratio of: 44/20=2.200
That spur gear shaft(86089) has the next gear on it which is a 18T(86097) drive gear that drives a 44T(100905) idle gear on the idler shaft(100905) for a ratio of: 44/18=2.444
On that same idler shaft is the next gear a 32T(86084) drive gear that drives a 29T(86098) idle/output gear for a ratio of: 29/32=0.906
The output gear shaft(86081) then feeds power to the diffs via the drive shafts(86246). The drive shafts feed a 13T(102246b) bevel gear in the diff which drives a 43T(102246a) bevel gear for a ratio of: 43/13=3.307
Multiply 2.200 x 2.444 x 0.906 x 3.307 = 16.109
So the stock ratio is 16.109
(From other post)------Hi, I have the following:
Diffs @ 3.307 (43:13)
Trannny @ top drive gear to first idle gear 2.444 (44:18)
Trannny @ second idle gear to output gear 0.906 (29:32)
Spur-Pinion @ 2.200 (44: 20)
For a total ratio of 16.109
With 14.8v, 2200kv and 6.3" tire the math for that combo is ~37.9mph
Where our math differs is the second gearing stage of the tranny.
I see the 32T gear on the idle shaft driving the 29T gear on the output shaft. Which means it would only take the 32T gear 0.906 of a revolution to turn the 29T output gear one full revoultion.--------
02.21.2009, 11:59 PM
Yep, that's right. With an actual manual in front of me now, I can attest that your part numbers and math is correct.
Nitro?? BL rulezzz
02.22.2009, 10:53 AM
If i have looked good, the gearing hasn't changed form the original 2 speed.
The flux gearing is the STOCK 1st gearing!!
Original 1st gear has 18/44, flux has....the same!
Greetz,
Joram
Standard is not an option!
Hybrid Mode
