sheared screw removal -
03.17.2009, 09:21 PM
I just broke a ball stud screw on my rusty. It just so happened that it sheared off in an aluminum castor block.  It is thread locked in there, and I know heat it up to disable the thread lock. But, how do I remove the screw without having to buy a screw removal tool?
Thanks!
I will spank a nitro any day...guaranteed. :)
Soldermaster Extraordinaire
03.17.2009, 09:32 PM
This a 3mm screw? Is there any part of it protruding that you can get a hold of? If you have a dremel, you could try cutting a notch in it and then use a flat SD to back it out after it's heated. Other wise you'll most likely have to drill it out or buy a new castor block because there aren't any extractors that will work on screws smaller than 1/8".
03.17.2009, 09:38 PM
It is a 3mm screw....and there is a little bit (like 1-1.5mm) sticking out the other end. My only worry is that the dremel wont leave much of a "wall" for the notch since the wheel is about 1.5mm thick. I'll give it a shot if nothing else is mentioned.
I would hate to ruin the castor block. The pair was close to $20 and I've only used them a handful of times.
03.17.2009, 09:43 PM
There are thinner cutting wheels available. They're cheap, too. THESE are the ones I mean. They are ~1mm thick and ~1" in diameter. just don't spin them too fast because they do self-destruct very easily. Oh, and WEAR GLASSES!!!!!
03.17.2009, 09:48 PM
I actually have some of them....I'm just worried that the "notch" wont be strong enough. I cant try it now...its dark outside. First light tomorrow I'll give it a shot.
Oh, they do self-destruct very well, I've noticed its mainly when they get too hot.
03.17.2009, 09:46 PM
vice grip pliers.
Originally Posted by brushlessboy16
vice grip pliers.
I dont think there is enough screw sticking out for that.
03.17.2009, 09:52 PM
You may need to cut into the aluminum to get a good grip on it. Not enough to hurt it structually. You could say it happened in a crash so it would be like a scar and, therefore, cool.
03.17.2009, 10:00 PM
True. I do need to find some different ball stud screws....I shear one a week at least (they are associated). I saw that lunsford sells Ti ones, but they are $8 a pair!
Can't catch this...
03.17.2009, 10:05 PM
and how much does an alloy caster block cost??
03.17.2009, 10:42 PM
Well, this is actually the first time I've sheared one in a castor block. Nine times out of ten, I sear one in the front shock tower.
03.18.2009, 05:41 PM
I got it out.  I did the notch trick with my trusty dremel. Aside from the nick in the castor block now, it worked like a charm.
I'm not sure why I didn't think of the notch trick before...I've had to do it before also. Thanks what's-nitro for reminding me.
03.18.2009, 06:51 PM
if it is fLM jamie will help you out...
03.19.2009, 12:01 AM
Good to hear Rusty! You're welcome!
Hybrid Mode
