Front Tower in the rear?
Fast5sRevo88
Front Tower in the rear? - 03.20.2009, 03:13 PM
Would it be possible to put the front shock tower of my CRT on the back if i got rid of the wing mount and got another set of front shocks to put on it? The reason i ask is that this would make the rear body post height the same as the front which would allow a regular MT style body to fit on it properly.
03.20.2009, 09:35 PM
Why dont you take off both towers, then try to mount the front one on the rear- you will soon see if it will work or not, and whether you have any fitmeent or shock related issues.
If it does work, then you can go ahead and order up another front tower to fit to the rear end permanetly.
Logic + common sense = success
