MMM and Losi Conversion Kit
Foxracin
MMM and Losi Conversion Kit - 03.26.2009, 09:55 PM
Just ordered a MMM 2200 setup and going to be using a Losi conversion kit on a 8ight. What is everyone doing to mount the motor on the Losi mount? It uses 4mm scews.
Ive seen some people take the end of them motor off and drill and tap it to 4mm. I wouldnt have a problem with that but I emailed castle and they said it will void the warranty if the motor is opened.
I have also seen people just use regular 3mm screw in the Losi mounts. The head sits low in the hole though.
Whats everyone doing about this and what would be the strongest without voiding warranty?
Thanks for the help.
auto2
03.26.2009, 10:25 PM
i used a spacer i got from mike and drilled a 4mm hole in the spacer. very simple and fast.
Foxracin
03.26.2009, 10:36 PM
Did you still have enough room to mount the pinion gear? I have heard the Losi mount is kind of wide and its tight as it is. Have any pics of your setup?
azjc
03.26.2009, 10:33 PM
I hated the Losi mount and used the RCM mount
http://www.rc-monster.com/proddetail...d=RCMLosiMount
Foxracin
03.26.2009, 10:37 PM
Why did you hate the Losi mount?
azjc
03.26.2009, 10:40 PM
the thickness of the mount and the 4mm fastners, they made it for thier own BL motors, I really like the RCM mount
