View Poll Results: Do you want new switches
Yes 76 84.44%
No 14 15.56%
Voters: 90. You may not vote on this poll
Petition for new switches
brushlessboy16
brushlessboy16's Avatar
Petition for new switches - 04.21.2009, 09:11 PM
Today while running my truggy along with Eovnu87435ds and his buggy. Both cars are running the MMM v3. upon landing jumps the esc shuts off, come to find- the switch gets flipped to Off by the force of the landing. this happened numerous times to both vehicles.
Castle Creations please include switches that match the quality of your speed controllers.
04.21.2009, 09:16 PM
Sure, I'll vote yes, but I usually replace them anyway...
BitHed
04.21.2009, 09:19 PM
...Meatloaf sang...'You took the words right out of my mouth, must have been while you were...' OK...well, lets not go there
brushlessboy16
With them changing switches you wont have to(hopefully)
i just cant have that happen on the track.. I need to replace mine or bridge it. havent decided yet.
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
04.21.2009, 09:23 PM
I usually mount mine the opposite way so the impact turns them on rather than of off.
Unsullied_Spy
Unsullied_Spy's Avatar
04.21.2009, 09:25 PM
If using a better switch means the ESC will cost more then no. I'm fine with cutting off the switch and grounding the wires together or solding the traces on the PCB together. The only thing a switch is handy for is re-binding my Spektrum.
brushlessboy16
My switch is mounted facing up. with the slider at the top perfectly vertical and a landing shut it off. no side-to-side motion on the truck at all
04.22.2009, 02:33 AM
if landing a jump is shutting it off then its a switch position problem, not a switch problem. moving the switch would cure your problem.
I believe the switch should be mounted in the esc case. There are enough things to mount, and enough wires.
switches.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
switches. - 04.22.2009, 06:43 AM
I plan on just cutting my switch off and installing a switch from a PC power supply. They are very good quality switches and should do the trick nicely.
SUPERMAXX YOUR LIFE.
brushlessboy16
04.22.2009, 07:33 AM
The impact of landing flipped the switch off... And Eovnu's car has the swtich mounted laid down. and hard landings flip it off too.
orientation doesnt change it.
castlemike
04.22.2009, 01:12 PM
I personally dont like our switches either....but I have never had one shut off at any point while racing. Not in 1/10, or 1/8 racing. I think its all about how you mount it. I always mount mine in a front to back orientation with the car and always put "on" towards the front. ( a lesson learned running 1/8 nitro )
RBMike
RBMike's Avatar
04.22.2009, 02:32 PM
I've never had it switch of but I've had a couple of the switchs just stop working. Just cut it off & solder the wires togeather.
InsaneRC
InsaneRC's Avatar
05.05.2009, 06:47 PM
i vote no don't need to change switches or get rid of them like to have an on off switch takes the hastle out of remembering to turn on radio before u plug in batts even when u get older u tend to forget and you end up with a smash up truck
Mat
Eletric is the New Nitro!!
Traxxas E-Revo
Marui Big Bear
Ofna Ultra LX-1E
brushlessboy16
05.05.2009, 08:54 PM
Mind saying that over? i dont understand
brushlessboy16
05.06.2009, 12:03 PM
gee srry was typing my word
sorry if we came off a bit agressive? i just cant understand what your saying in your post
