My e-maxx is too heavy...
jalodo56
My e-maxx is too heavy... - 05.31.2009, 05:46 AM
hello I have an e-maxx that weight 13.2lbs rtr, with FLM chassis and Hybrid Bulks with 1/8diffs, and have 1/8CD, the e-maxx have all of rpm parts, and have 4 shocks of front buggyes, and 4 bigbore traxxas with big wheels.
The truck run with a neu 1515 2.5d on 5s 5000mha with ezrun 150A it is gear for 45mph. The motor is enough?? What can I do for reduce weight?
regards
weixc
05.31.2009, 07:34 AM
yup 13.2lbs is a little heavy But run with 1515 motor I think is enough
aqwut
Brushless Heavy Weight....
aqwut's Avatar
06.01.2009, 12:05 AM
I don't think 13 Lbs is that bad.. mine is 14Lbs on a creap Feigao 12XL motor.. you should be fine..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
jalodo56
05.31.2009, 10:28 AM
I can reduce weight using only 4 buggy front socks, but I don't know if it with hard spring are enought for an heavy truck because I want to jump high.
regards
PD: Anoter recomendation for reduce weight?
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.31.2009, 11:03 AM
Either go up to 6s, gear down to around 38, or swap out motors for the 2200 1y.
The other factor more than just wait is your wheel/tire combo. Heavier tires and wheels create a lot of drag on the drivetrain and motor. This is much more a factor of performance than just static weight alone.
But really are you having problems with your setup like it is?
www.cubicle101.com
jalodo56
05.31.2009, 11:08 AM
the truck have a lot of power, run well.... but how it is too heavy the truck break easier than a 11lbs truck,that is the weight that I want., and when it landing of a jump it touch the ground
TexasSP
TexasSP's Avatar
05.31.2009, 12:15 PM
Maxx's break a lot period with that kind of speed.
www.cubicle101.com
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
06.01.2009, 12:50 AM
mine is 12.5lbs and I have exact shock setup as you do. 4 1/8 buggy shocks and 4 traxxas big bores. try to put these springs on your 4 traxxas shocks, will help with car hitting the ground on big jumps.
http://www3.towerhobbies.com/cgi-bin...?&I=LXCSE0&P=7
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
