revo+3905 trans help
mopar1994
mopar1994's Avatar
revo+3905 trans help - 06.18.2009, 05:30 PM
i just got a e-maxx 3905 trans for my brushless revo 3.3 and i need some help mounting it. ive looked at all the other threads that have pictures of 3905 transmissions mounted in revo's but im still not really sure what parts of the chassis need to be shaved off. i was going to make a bracket like jzemaxx did on his revo but i need to know what parts of the chassis need to be shaved down. pictures would be helpfull.
06.27.2009, 05:50 PM
I know you've seen it already, but just look a little harder. All you need to do is offer up the 3905 tranny to the big hole in your revo chassis, and it should be immediately clear where you need to remove material to allow the tranny to fit flush with the chassis. Then, make a cardboard (cereal box is best) template that allows you to mount the tranny on the side that needs extra chassis material. You should also be able to see where you need to drill holes to mount the tranny on either side.
Print out that picture and the others to use for reference (they didnt have any help so it really isnt that tricky, just needs a little imagination- remove a small amount of material each time, rather than all at once....).
