Mamba Monster 2200k combo Punch Control and other settings
Mentat
Brushless Mentat
Mentat's Avatar
Mamba Monster 2200k combo Punch Control and other settings - 06.22.2009, 08:57 PM
Final getting things together with my 8ight-T 1.0, and was wondering were i should set punch control? im running 45t spur with 18pin and 4s lipo 5000mAh. I dont want to break anything and do not care about flipping the truggy on its lid. Also i have 4 and 5 cell lipos what is a good setting for low voltage cut off?
FS: 8ight-t Race Roller TONS of UPGRADES
8ight 1.0 & 2.0 | 8ight-T 1.0 & 2.0 | E-Revo BL Edition | T-Maxx | Slash | Raze-ST | XXX-NT Drake | 3PKS | DX3S Telemetry
06.22.2009, 09:05 PM
autolipo 3.2v
punch 25%
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
06.22.2009, 09:09 PM
the new castle link software download let's you custom your lipo cut-off voltage...however, the auto-lipo feature dosen't always work so well....what i do is take the lowest cell voltage i'm comfortable with and multiply it by the # of cells i'm running...ie: 6S at 3.3V per cell is a cut off of 19.8V....the point is you never want your individual cells to drop below 3.0V per cell.
as far as punch control...i love wheelies, huge acceleration etc...i use 0%. if i'm track racing, i can usually run between 40-70%. if i'm bashing in grass/trails, i use 0% as well.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
bdebde
That's All Folks!
bdebde's Avatar
06.22.2009, 09:25 PM
I set my cut off to 3.25 v per cell. I don't like the punch control on my racing buggy (use my finger), but I do use some punch control on most of my other rigs. The Punch setting is something you will have to set to your own preference.
06.22.2009, 09:37 PM
I set my lvc @ 3.3 just for piece of mind.
stum
06.22.2009, 09:40 PM
Auto-lipo 3.0 is fine, 3.2 if you have junky lipo's but normal packs can handle 3.0 w/o issues as 2.7v is actually when a lipo can be damaged.. 3.3v is overkill and just cuts drastically into your run time as you can't burn through all your packs mAH before hitting a LVC.
Punch is a tricky one.. if you put on too much punch you loose throttle control while you are in the air, if you do too little it can make it hard to get traction really fast.. I typically set mine at 10% to 20% never more, even at 30% I find you loose just a little too much control while in the air (gas'in up to level out).
I do always set my timings to low (5), Zero drag brake (causes more heat than good), and to be honest I use the mechanical brakes so I disable the brakes and reverse completely.
Runs great, and the only thing that keeps me from winning at the track would be my skills :) LOL Getting better but still not up to the top 2 or 3 drivers yet... closer all the time though.
Ryu James
Ryu James's Avatar
06.23.2009, 02:05 AM
last time i looked my MMM manual said that the lipo auto cutoff feature only worked for 2s and 3s. is that still the case or am i confusing this with some other controller? just to be safe i always set mine custom at 3.0v. per cell or 15.0v for my 5s packs. when my ride starts dying down and cutting out i throw the pack on the charger and it usually is at like 16.5v so it doesnt ever even get close to the 15.0v. because the shorts bursts when you gas it drop the pack down to the cutoff point you should never be able to get your pack actually down to the cutoff point for more than a split second....i think.
Jammin SCRT10 Neu 1512 1y
Mentat
Brushless Mentat
Mentat's Avatar
06.23.2009, 02:15 AM
Yeah the auto lipo is for 2-3 cell. i just set my according to the battery i use. When it starts feeling like its losing power i charge it.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
06.23.2009, 06:18 PM
The mmm beeps the number of cells that it detects when you turn it on and works for 2-6s packs. IF you know how to count, there's no reason to use a single cutoff instead of auto-lipo for multiple packs.
Area 52 Ranch Raceway
T.R.C.R.
Freezebyte
06.23.2009, 06:26 PM
This LVC point is about a hot of a topic as abortion. People will swear to hell and back to never go lower then 3.3v cutoff point. Other peeps feel fine at 3.0v. Other state it all depends on the battery quality that warrants wether going higher on the LVC is good or a waste.
I just ran on my Flux at a timed 28 minutes at 3.2v today. I was surprised how much less run time I got vs my 3.0v cutoff. I think I may go back. Im gonna check my charge mAh to see exactly how much it actually discharged the batteries at that level. I run SMC's, so I think i'm gonna push them a bit harder then what many folks would deem safe, but in the end, its my truck, I do with it as I please.
As far as punch, i'm still playing with that even after a month of having the Flux. I finally got the brakes where I want them, proportional with reverse cutoff at 20% brake with 10% drag brake. Punch control at 30% seem to be a nice level for my bashing needs
jzemaxx
06.23.2009, 09:20 PM
I run 3.0V cutoff
Everything else is set wide open. lol
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
SpEEdyBL
SpEEdyBL's Avatar
06.24.2009, 07:41 PM
If you are getting noticeably more runtime at 3.0 volts vs. 3.2 volts, your packs are not good enough. Good lipo packs with properly matched cells will stay strong, suddenly hit the cutoff and be done. At least for my packs, the voltage curve is so steep that there is really no difference in time between 3.0 volts vs. 3.2 volts per cell, so there is no reason to run 3.0 volts when you can run 3.2 volts.
T.R.C.R.
stum
06.25.2009, 06:37 AM
I've never seen a pack that does a full on dump and holds a flat curve going from 14.8v to 12v or (18.5/15 - 22.2/18) and I've seen a lot of eagle tree data. Typical packs even good ones at about 85%-95% of capacity start to drop and the .8 to 1.2v difference means anywhere from 300-900mah (1-3mins) depending on how good the pack is. It maybe only 1min range for a TP, FP, Elite, Neu type pack and closer to the other end w/ some lower quality packs, but it does make a difference.
Lets see your eagle tree or at least some detail about these packs that hold a 14v line until the second they dump... I'm very interested in getting some LOL
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
06.24.2009, 07:49 PM
Auto-Lipo
Start @ 50% PC and go from there for personal taste.
bdebde
That's All Folks!
bdebde's Avatar
06.25.2009, 08:45 AM
I see some of you say to set the LVC to 3v to get more run time. What you may not realize, a lipo pack will live much longer if never discharged below 80% of capacity, and by running down to the very lowest LVC setting, you are just killing your packs faster. Is it worth the couple minutes run time if your pack only lives half as long?
