How about this bl setup?
RC Fan 4 Life
How about this bl setup? - 01.30.2006, 12:29 AM
wanderer 9xl
BK Electronics 12020 Warrior Controller
using 16 cells GP 3300
I would like to hit 50mph or high 40's and still have arm pulling off torque.
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
01.30.2006, 07:34 AM
only 16 cells? i'd go with 18 or 20.
  Send a message via AIM to nbcaznmaster
RC Fan 4 Life
01.30.2006, 12:04 PM
because i have packs of 7 cells now and i'd only need to add one more cell to each of them plus i would still be able to use my MRC dual charger.
Do you think my maxx would hold up to the 9XL on 16 cells? So far i have added...
UE 6 diffs
MIP CVDs all around
Single speed trans with steel ideler gear + FLM half case.
Hi Tech ultra torque steering servo
RR slipper clutch
crazyjr
crazyjr's Avatar
01.30.2006, 08:51 AM
I would say 18 is the limit with a 9XL. Coolhand_country has tried20 cells and said it would heat up to above comfortable levels.
Serum
Serum's Avatar
01.30.2006, 10:28 AM
yeah, that setup sounds like the one for you.
16 cells, and that speed is fair easy to achieve.
boss 302
01.30.2006, 04:56 PM
it should last but i would recommend upgrading to the strobe slipper
RC Fan 4 Life
01.31.2006, 10:47 AM
Any other suggestions guys? Before i buy. :)
Am i going with the right motor?
coolhandcountry
coolhandcountry's Avatar
01.31.2006, 12:52 PM
The mip may hold. I have seen them break. I like the ue much better. But that can come later. That motor is good. I like it. It gives me good run time and great power. especially on 16 cells. 18 51 gearing on the strobe works well. !6 51 give you a little longer run time.
RC Fan 4 Life
01.31.2006, 01:32 PM
coolhandcountry... are you using this setup? Got any pics of it and how fast do you think it will go and hows the torque?
coolhandcountry
01.31.2006, 01:40 PM
I run a 9xl with a 9920 right now. I have ran it from 12 to 20 cells. 20 seems a bit much. get a little warm. I have some video on the net to. www.rcpics.net/members/coohandcountry
this should have a video. Look up in the forum under extra long gmaxx I think itis.
RC Fan 4 Life
01.31.2006, 01:48 PM
That link comes up as ...Your search did not have any results.
Nick
COOKIES!
Nick's Avatar
01.31.2006, 01:47 PM
I've bent MIP CVDs on a 7XL with 14 cells. Depends how you use your truck though, I was been abit crazy.
~ Nick.
RC Fan 4 Life
01.31.2006, 01:56 PM
Got a link to the UE's that fit the stock maxx? I found 2 pins missing on the MIP's
boss 302
01.31.2006, 04:35 PM
here is 6mm cvds for the widemaxx http://www.rc-monster.com/proddetail...13501s7&cat=47
RC Fan 4 Life
02.01.2006, 12:28 PM
thanks for the links! I forgot to ask will this setup fit the stock chassis?
