stronger diff output ideas
mkrusedc
NeuMaxx
mkrusedc's Avatar
stronger diff output ideas - 06.28.2009, 04:42 PM
I broke a diff output on my HotBodies. I think the truck landed off a big jump on just the left rear wheel. The output shaft twisted and sheared at the place where wheel drive shaft attaches. Are there a stronger options? Someone recommended Savage upgrade diff cups. Any other ideas?
(my brother-in-law was driving. he probably landed WOT on that wheel)
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
06.28.2009, 05:07 PM
Hmmmmm, I broke just about everything on my LSP's but never a outdrive cup ?
No clue for a aftermarket hopup for that ? I also think anything Savage will either be the same exact part (strenth wise) or not fit.
If you find something please post, I'm curious to see whats availible ?
06.28.2009, 05:21 PM
Do you mean the rcm diff output shafts for the hybrid bulks? I am guessing you are either using cvds on the maxx or the stock sliders? I think this was discussed before and Mike was going to make a stronger/redesigned set?
mkrusedc
NeuMaxx
mkrusedc's Avatar
06.28.2009, 05:28 PM
Thanks for answering James. They are the original HotBodies output shafts because I was using 3.3 sliders. I will upgrade to UE cvds when I fix this though. Did Mike ever do it?
06.28.2009, 05:43 PM
Not sure if he redesigned them or not. Chris (Arct1k) had a thread about this IIRC. If you are using the sliders you must have a set of the rcm diff outputs, cause the hb outputs have a built in dogbone cup, like any other 1/8 diff output.
06.28.2009, 08:39 PM
I would just replace like with like- its a $5 part (or a homemade effort made from a stock traxxas stub axle trimmed down, $2 part) that probably wont ever break again, just a fluke occurence...
mkrusedc
NeuMaxx
mkrusedc's Avatar
06.28.2009, 08:51 PM
Thanks, I think that is what I will do.
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
06.29.2009, 01:35 AM
I use HotBodies diff too and the output its very soft and easy to break thats fact.
now I use this Traxxas Stub Axle Steel Revo I just cut the thread by a dremel :)
MMM v1 zippy 2x3s 5000mah neu 1y 1/8 diff's
MMM v3 Rc-monster 2x2s 5200mah-HC medusa 36-70-2300kv
Pic's - video - youtube video's
mkrusedc
NeuMaxx
mkrusedc's Avatar
07.18.2009, 12:47 PM
Need a little help remembering. What is the easiest way to replace my output shafts? Do I have to take the ring gear off of the cup or do I use the grub screw that is in the cup?
07.19.2009, 04:27 PM
Both- you need to dismantle it pretty much to replace both outputs:
http://www.rc-monster.com/forum/showthread.php?t=8012
