LBA 10 balancer question
LBA 10 balancer question - 07.12.2009, 03:57 PM
This is directed to anyone who uses a pair of lba 10 balancers, networked together, to charge a pack 7s or more...
I have an emoli lipo pack for my milwauke drill, 7s 3000mah. The little internal lvc or whatever has crapped out, so I want to just set the pack up to charge off my 1210i. I would also like to add a balancer harness.
I have a pair of lba 10 balancers, and the correct network cable for them. The hyperion diagram shows them setup in master/slave mode, but does not show them hooked to a single battery pack, just 2 packs. So I am wondering if I can use a serial harness on the outputs of the balancers to allow me to hook up the 7s pack? I had planned to put a 3s and 4s hyperion balancer taps on the pack, and just use the main pack outputs to hook the serial-wired charge cable to. I could wire the packs as a 3s and a 4s for charge purposes, but still use the main output to power the drill. I would prefer not to have to do any more wiring than necessary.
07.12.2009, 05:33 PM
If I understand you correctly, you want to run 3s to one LBA10 and 4s to the other, both networked. I'm not positive, but I don't think you can do that. You'd be better off IMO to make an adaptor so the 7s pack is split into a 6s for the primary LBA, and 1s for the secondary LBA.
07.12.2009, 06:05 PM
I can get it to balance wired as a 3s and 4s, just will not work in connection mode. I figure that if I cannot make this work I can physically split the pack into a 3s and 4s so that I can charge and balance them as a 3s and 4s and then wire back into series to run the drill. I figured that I cannot make it work if the pack is wired as a 7s, no matter what I do with wiring. I can use some powerpoles to do the connections, so it should work...
I know that a 720i would work... Bit 200 bucks for a charger that I do not need....
wallot
wallot's Avatar
07.12.2009, 05:46 PM
new hyperion chargers can balance 7S :) (like EOS720)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
07.12.2009, 06:21 PM
So, you already have the pack split into 4s and 3s. OK, then make an adaptor to go from 3s+4s to 6s+1s. I'm sure this would work.
07.12.2009, 08:55 PM
Not split as far as the 7 cells in series goes, just wired for a 4s and a 3s balance tap. I will try the 6s and 1s setup you suggest, but I still wonder if the outputs of the 2 lba balancers do not like being run into a series adapter... I think that may be my issue. I will report back, need to use the drill as it is fully charged now!
07.12.2009, 10:26 PM
I'm sure you know this, but you did flip the little M-S switch right?
07.12.2009, 10:46 PM
Yep, made sure the entire setup worked properly with a pair of matched 3s packs. I really think it is the series adapter that I am susing to link the 2 lba outputs together that is causing the issue.
I can get the 2 balancers to do the stand alone balancing, but as soon as i try to put them in connect mode it gives the error.
I will give your idea a try Brian, but think I will have to set the pack up as a 3 and a 4s, and then have a connector that will bridge them for series. That way I can remove the bridge and charge as 2 packs with the dual lba setup as it was intended to be used... Just a little more wiring, not too bad. Luckily their is a decent amount of room since I have removed the internal lvc/circuitry, so I can set something up there. Just need to find some samller than 13 gauge wire for charging, as the thick stuff will not fit the pack very well.
