A new 8ight-T 2.0 is born
PBO
RC-Unobtainium
PBO's Avatar
A new 8ight-T 2.0 is born - 07.18.2009, 09:06 PM
Not quite the build thread that others (Dave) have posted but...
Feel free to offer tips if you have them
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
07.18.2009, 09:50 PM
very nice build
07.18.2009, 10:05 PM
Looks good. I like the angled bullet connectors. You can mount your switch in the radio box. Just extend the wires a bit and shrink/ziptie them to the rx wires.
Kcaz25
Kcaz25's Avatar
07.18.2009, 10:15 PM
What is going on with the extra cap? Just adding to the bank?
PBO
RC-Unobtainium
PBO's Avatar
07.19.2009, 01:26 AM
I've got a TRX mount coming for the switch & I thought the extra cap might just be a good idea? the V2 has had plenty of Rustler speed runs through it
I think I'm stuck for out of the way cap locations? would an alloy brace work as a heat sink on a cap?
Losi 8ight-T
PBO
RC-Unobtainium
PBO's Avatar
07.19.2009, 01:39 AM
This shows the battery plugs. I'm going to mount some CF for the TRX to mount on, which should also raise the lowest motor wire above the rear CVD, it's a little close
Losi 8ight-T
bryan
bryan's Avatar
07.29.2009, 07:44 PM
looks good here are some pix of my 1.0 conv. my converted 2.0 is in the mail, cant wait!!!!!!
Snipin_Willy
Snipin_Willy's Avatar
08.03.2009, 10:11 PM
BRAID THOSE MOTOR WIRES FOO
OZ-RUSTLER
OZ-RUSTLER's Avatar
07.30.2009, 03:12 AM
Nice conversion PBO.
What motor you using?
PBO
RC-Unobtainium
PBO's Avatar
07.30.2009, 07:18 PM
Thanks Oz, I'm using old faithful, the 1.5 - love my Neu!!
I've repositioned the cap & added an additional...a photo or two soon
Losi 8ight-T
cavy
07.31.2009, 11:45 PM
Looks nice i just started building mine what gearing u running? I read somewhere robinson 48 an 16
PBO
RC-Unobtainium
PBO's Avatar
08.02.2009, 08:23 PM
I'm running 48/20, which is about the limit for my 4S setup I feel. I've given it the speed run torture test on grass, 2 x 3300 packs back to back & everything ran as warm as I like
I went to the track yesterday & noticed the MMM glitch at startup...it chirped but had no steer or throttle for about 15 secs. It came good & I was nannaing it around for a while, then mid jump (a small one) I lost throttle & rolled forward for a heavy thump on it's lid
Closer inspection showed a fet loose inside the MMM, it was easy to see because the MMM was in half! despite cable ties
Not sure if Castle will look at as a replacement but I'm thinking of an RX8. I may be forced to use my MM until resolved
Losi 8ight-T
cavy
08.03.2009, 10:08 PM
Yeah that rx8 motor looks sweet Did you have to grind down the chassis to run that 48 thooth? I ask because i just picked up the robinson gear and it hits the bottom.
PBO
RC-Unobtainium
PBO's Avatar
08.04.2009, 12:57 AM
I didn't need to but I'm using the Losi spur & I'm not sure if the RR is larger (I don't see how it could be?), which kit are you running?
Losi 8ight-T
cavy
08.04.2009, 09:22 AM
I got the race roller. Yeah it's rubs at the bottom.
