how to remove a traxxas high current connector
auto2
how to remove a traxxas high current connector - 07.18.2009, 10:39 PM
ok how do you pull the termanal out of the connector?
sikeston34m
sikeston34m's Avatar
07.18.2009, 10:45 PM
I put the connector, wire side down, on the table edge. Then place the spade of a small screw driver against the end of the copper terminal. Then smack the end of the screw driver pretty hard.
Might sound a bit forceful, but it works.
auto2
07.18.2009, 11:15 PM
ok was wondering if there was a tab to stick something in/on/around. ill use your method.lol
sikeston34m
07.18.2009, 11:24 PM
Not that I know of. If you look closely at one of the terminals removed, it has one tiny tab that is turned up, and one tiny tab that is turned down.
It is these that provide the "snap" when you seat them. The only way that I know to get em out is to over power those.
auto2
07.19.2009, 09:00 AM
ok i havnt seen one apart yet. just bought a 1/16 revo. and want to usr the male on the silly little battery charger that came with it to make an adapter so i can charge my new zippy lipos i bought for the revo with my hyperion. i just cut the wires and solderded a deans to the other end. its working.
nitrostarter
nitrostarter's Avatar
07.21.2009, 11:57 AM
side cutters... lol
N. Rustler conversion
07.21.2009, 01:25 PM
Hammer and chisel?
PBO
RC-Unobtainium
PBO's Avatar
08.01.2009, 07:47 AM
Hammer and chisel?
You don't need the chisel
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
07.21.2009, 03:58 PM
A pair of needle nose pliers works great for the male ends, use one side to just bite onto the tab and the other end on the backside of the casing, squeeze and they come apart pretty easy. For the females I place them on the edge of a block of wood and push the tab out with a screwdriver. I have taken apart at least 50 of these, they work over and over again without a problem
jpoprock
jpoprock's Avatar
08.09.2009, 11:39 AM
I just put my connector, end up, in a vice. I then take a small flat screwdriver and place it on the end of the connector bar, and gently tap it with a hammer, and it will push right out of the other end. Very very simple.
Just take note of which side you solder the wire to, because one side of the blade has teeth, and the other side doesn't. Teeth side go down into the housing. Also, make sure that when you solder the wire to the blade, you don't go any farther than the line indicated on the blade, and try not to allow solder to cross that line either. If you get too much solder on there, you'll have problems getting it all the way in. And if your blade gets bent, or has any solder on it, you'll have a really hard time pushing it thru also.
Sometimes after it's pushed in as far as I can get it, if not all the way, I'll put it in a vice, this time where the wire goes into the connector, and gently tap it into place with the screwdriver and hammer.
It's very very easy.
Again though.. you have to watch how much solder you use, and you can't be messy with it. I've found that of all the connectors, these are the trickiest to get just right. You also have to make sure that your wire is aligned straight with the blade too.
  Send a message via Yahoo to jpoprock Send a message via AIM to jpoprock
